Old July 20th, 2010, 01:16 PM   #1
gogiburn
Motorcycle(s): have 24
Motorcycle helmets cams
What are you using and Pro's and cons on the unit?I'm looking at the Sony 580 and Contour HD as possible choices>
Posted via Mobile Device
gogiburn is offline   Reply With Quote
Old July 20th, 2010, 01:27 PM   #2
revstriker
revstriker's Avatar
Motorcycle(s): 2009 Ninja zx6r
I've got the GoPro HD, although I don't attach it to my helmet (Others do).
revstriker is offline   Reply With Quote
Old July 20th, 2010, 02:30 PM   #3
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
I've got the ContourHD (720 version, not the 1080P out now). It's light weight, seems to work well, I've got it on my helmet and use it everytime I ride.
Pros: Relatively inexpensive (the 1080 is much more $), takes fair quality video, has decent support from the manufacturer, is fairly easy to use. Takes up to 16G MicroSD cards. Laser aiming for both direction and level, can be done with the camera fully mounted and ready to go.
Cons: Not waterproof at all despite claims to the contrary, so you need to buy a $40 waterproof case if you plan to ride in rain. Stick-on pad mount won't stay stuck to any curved surface such as a helmet; it will slowly peel off. I was lucky, I found my camera under the counter in my kitchen where it had fallen off overnight. I ended up pop-riveting the mount to the helmet. Low-light performance is definitely lackluster. No remote mic jack or ability, so lots of wind noise if not mounted behind a windscreen. Beeps to indicate on/off/recording status aren't loud enough to hear over the wind when you're moving. No external power ability;can't record while charging. Records into an oddball MOV variant that editing packages like Vegas Studio has problems with, typically loosing sound or sound synch. Can't disable auto power off after 10-15 minutes of non-recording time.
Now, don't take all the cons to indicated I dislike the camera; these are for the most part relatively minor issues except for the adhesive pad problem, that was almost an LOC event. Most of these cons relate to how I use the camera, which is to record every moment I'm riding and not just specific events or activities. For the $169 I paid through amazon it's a good camera, though having to pony up an extra $40 for the waterproof case was disappointing.
What I really want is a Clubman Pro4 from Stack Electronics, but that's two grand so it's out of my pricerange.
Old July 20th, 2010, 03:35 PM   #4
gogiburn
Thanks for th info,I'm concerned about your comments about what format it records to??
Old July 20th, 2010, 04:47 PM   #5
Soujyu
I know you aren't considering the GoPro HD, but that's what I use.
You have to attach it to your helmet (at least somewhere that isn't actually on your bike) because attaching it anywhere on your bike causes vibration to really show up in your recorded videos. It comes with a waterproof case, and it records to MP4 format, which is easily editable using most programs without much hassle at all. In particular, iMovie on the Mac will work with it just fine.
It has a big pile of attachments, including curved bases that work really well on a helmet. I know you might not have considered the GoPro HD because it is a bit more expensive than the Contour HD, but it's well worth the extra $$$.
Not all helmets are created equal. Shark helmets commercial spooph Motorcycle Gear 9 April 7th, 2015 06:34 AM
How to identify cams? Zombarian 1986 - 2007 Ninja 250R Tech Talk 3 August 19th, 2014 01:06 AM
Uhh...My cams do not fit? m0biusace 2008 - 2012 Ninja 250R Tech Talk 4 May 20th, 2014 03:04 PM
5 Action Cams - Where to mount them? SSG54 General Motorcycling Discussion 14 September 6th, 2013 01:19 AM
Web Cams (performance) mgentz 2008 - 2012 Ninja 250R Tech Talk 6 December 1st, 2012 08:53 AM
