February 9th, 2012, 12:08 PM | #41 |
R&T Suspension
Join Date: Jun 2009 Motorcycle(s): Too many to list Posts: 175
And that design doesn't work
February 9th, 2012, 12:18 PM | #42 |
CVMA #74 WSMC #750
February 9th, 2012, 08:00 PM | #43 |
L8APEX
Join Date: Nov 2011 Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org! Posts: 233
www.joemillersmoderngarage.com www.starr-cycle.com ***The most important concept of science isn't memorizing facts, it's observation of phenomena.*** |
February 9th, 2012, 09:54 PM | #44 |
R&T Suspension
I build all types of road race bikes. I've built quite a few EX250's that have won in CMRA. Also did the suspension on the CBR250 that has been doing well out there. Basically same suspension as the EX. But the CBR has a better chassis.
I haven't ridden an old gen in a couple of years. The last one I rode had new gen forks w/ new gen rear wheel. We built it because our old gen had a couple more hp, but when the motor finally let go it was parked. Only pic I have on a new gen. http://www.flickr.com/photos/9479484@N02/6849984643/ Last futzed with by ROADandTRACK; February 23rd, 2012 at 04:55 PM. |
March 15th, 2012, 10:20 AM | #45 |
OMRRA 701
ArmourBodies Fender attachments
Further to this conversation, I am wondering if it is required/necessary to attach a race bodywork fender (such as ArmourBodies) to the two mounting points along the top of the fender on the back side.
It is still unclear how much of the bracket needs to be retained even if one makes the decision to "get rid of it". Any pix of various race set ups on the front fender and bodywork would be greatly appreciated! |
March 15th, 2012, 03:14 PM | #46 |
Join Date: Nov 2011 Motorcycle(s): 2005 HON CBR1000RR Repsol, 2012 KAW Ninja 250R Posts: 131
My Sharkskinz front fender does not use those mounting points... see attached pic. Stock on left, Sharkskinz on right.
March 17th, 2012, 10:05 AM | #47 |
Join Date: May 2009 Motorcycle(s): Too many. Some are in the house. Posts: 75
I run the brace. I guess I'm not going fast enough.
March 19th, 2012, 04:34 PM | #48 |
R&T Suspension
March 19th, 2012, 04:50 PM | #49 | ||
Join Date: Mar 2012 Motorcycle(s): 2011 Ninjer 250, 2002 TL1000R, 2009 Concourse14, 2009 ZX6, 2006 SV650 Posts: 19
Just me or are these two exactly opposide statements |
March 20th, 2012, 08:14 AM | #50 |
R&T Suspension
You are correct.
I think what is getting confusing is when I am talking about a fork brace I usually think of a real fork brace not that fender bracket. That bracket is huge and Kawi may have intended it as a kind of "fork brace" but it is not strong enough to affect much at race speed. |
March 20th, 2012, 09:50 AM | #51 |
Name: Zander the Expander
Join Date: Nov 2011 Motorcycle(s): 2010 Kawasaki 250 (Track scooter) 2012 Triumph Daytona 675 Posts: 153
so should i ditch this thing or what?
March 20th, 2012, 03:12 PM | #52 |
you guys are confusing me. at what point are you getting chatter? fork braces on standard forks are supposed to help keep the fork lowers from twisting around the uppers and twisting the wheel, right? that doesn't seem to me like it effects braking much, considering the front stays rather calm in terms of sway movement under hard braking until it starts locking from too much brake... now if you are talking about twisting on turn in when trail braking, i could understand that being helped by a fork brace. the force of braking is on one side of the tire... could cause it to twist a little bit... or if you are heavy on the bars with your turn in... a fork brace would definitely help keep that from happening (excess twisting of the wheel compared to the bars). though, when this is all happening, the forks are compressed, so a fork brace is almost completely useless... what effect the front wheel twisting a little bit has on handling or performance... i almost want to say it has none outside of wear on the forks... if someone can explain otherwise please by all means... i mean, yes the bars will twist more than they "should" when its flexing like that. but that seems like the only difference? doesn't really effect handling...
March 20th, 2012, 03:15 PM | #53 |
CVMA / AFM / M1GP #250
Join Date: Sep 2009 Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650 Posts: A lot.
March 21st, 2012, 01:16 AM | #55 |
I sat on the bike after it had been sitting all winter and thought I was getting chatter at a stand-still until a couple of Akima's angry friends came out of the fairings and started harassing me.
March 21st, 2012, 06:05 PM | #56 |
March 22nd, 2012, 05:17 PM | #57 |
R&T Suspension
Nothing wrong w/ keeping the OEM bracket.
March 22nd, 2012, 06:48 PM | #58 |
CVMA #74 WSMC #750
Werd.
I can vouch for Wes.
October 20th, 2015, 02:30 PM | #59 |
Join Date: Mar 2015 Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB Posts: 281
So to relive a super old post... Did anyone do this? With that results?
October 20th, 2015, 07:47 PM | #60 |
5 - 7 inch piece of bent metal on my bike | IF13 | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 21st, 2013 02:51 PM |
Front Fender - Metal Bracket Removal | Rollin.. | 2008 - 2012 Ninja 250R Tech Talk | 4 | August 14th, 2013 06:35 AM |
metal stock | alex.s | Off-Topic | 4 | April 14th, 2011 02:39 PM |
2008/2009 Stock Blue Front Fender FREE! | TygaUSA.com | Motorcycle-related | 4 | July 16th, 2010 12:36 PM |
Selling - Stock '09 Fender/Blinkers (Front) | Brently7785 | Items Wanted | 5 | June 1st, 2010 09:49 PM |
