Old March 24th, 2012, 01:41 PM   #1
675Raisinator
675Raisinator's Avatar
Name: Zander the Expander
Motorcycle(s): 2010 Kawasaki 250 (Track scooter) 2012 Triumph Daytona 675
Tyga full exhaust leak issue
Installed my new tyga full exhaust today but noticed I could feel air near the linkages. I installed everything correctly with the springs and used a rubber mallet to make sure the pipes seated well. Is this something I can leave or would an exhaust heat wrap help? Should I just get the linkages welded? Not a fan of the springs but they were really tight and a bitch to get on there
675Raisinator is offline   Reply With Quote
Old March 24th, 2012, 06:54 PM   #2
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
Strange, I have no such air leakage on mine. Is this on all of the linkages?
But hahaha yea, those springs were a real b****
MikeBudd is offline   Reply With Quote
Old March 24th, 2012, 07:16 PM   #3
675Raisinator
It's where the headers meet the straight pipe
Old March 24th, 2012, 07:19 PM   #4
675Raisinator
Maybe sealant ? Heat wrap ? Help me
Old March 25th, 2012, 12:17 AM   #5
MikeBudd
MikeBudd's Avatar
If I were you I would pm bill (tygausa) about it and get his input. Or ask tyga themselves. There shouldn't be air leak, and if its something that's fine, they will be able to answer your questions.
I would think heat wrap could work, but it would be much better to talk to them first.
Old March 25th, 2012, 06:15 AM   #6
ator
ator's Avatar
I just installed the Tyga full exhaust myself, and yes, those springs were a b***h, I even broke one. But, no such exhaust leaks for me, sorry
Old March 26th, 2012, 06:37 AM   #7
675Raisinator
so this is what TYGA sent me-
Sometimes you'll have a minor leak where the slip fits are - and carbon buildup over a short period of time tends to seal things up. You might try loosening up the manifold bolts and mounting bolts a touch, giving it all a good wiggle to settle in, then retighten the various bolts. I've had success getting a perfect union/fit this way.
Old March 26th, 2012, 06:51 AM   #8
EthioKnight
Super Noob
EthioKnight's Avatar
Motorcycle(s): '09 Kawasaki Ninja 250R, '84 Honda Spree 50cc
Not to jack the thread, but I also have had a small leak right at the connection between my slip-on (Danmoto) and header pipe...have rode it as is for about 200 miles or so and am still waiting for it seal itself...I'll definitely look into heat wraps (there's a good one at autozone is what I hear). Anyway, just wanted to say thanks for saving me the trouble of opening a new thread
EthioKnight is offline   Reply With Quote
Old March 26th, 2012, 07:06 AM   #9
slayton00
FYI
About a month ago i ordered my tyga full exhaust and they sent me two of the same side header.. i was able to get it to fit still ( not knowing i had the wrong piece) and it had a pretty bad leak.. i tried a few things to stop the leak but nothing worked...soooo i called tyga and asked if both pieces were supposed to be exactly the same and they said no.. i immidiatly told them i had 2 of the same side and they sent me a new one priority mail. I got the new one in and everything fits perfect.
slayton00 is offline   Reply With Quote
Old March 26th, 2012, 07:24 AM   #10
675Raisinator
Nah I have left and right headers sorted ... thank you for the heads up tho ...
Old March 26th, 2012, 11:45 AM   #11
Lew360
Bueller
Lew360's Avatar
Motorcycle(s): '09 250R
A little Permatex Ultra Copper would probably seal it right up. I used it on my SV slip-on.
Lew360 is offline   Reply With Quote
Old March 27th, 2012, 12:32 PM   #12
When I bought my Two Brothers cans, they included RTV high temp sealant and instructed me to use it wherever pipes met. I've never had any leaks.
That might work for you.
FS: TYGA full exhaust CF can josefmd Motorcycle-related 12 May 2nd, 2013 05:38 PM
TYGA full exhaust(carbor fiber round can) josefmd Motorcycle-related 4 November 21st, 2012 08:30 AM
TYGA Full Stainless Racing Exhaust & Fairing Sonofswin 2008 - 2012 Ninja 250R Tech Talk 20 August 10th, 2012 02:40 AM
Tyga vs AreaP full system 675Raisinator Ninjettes At Speed 20 February 8th, 2012 09:12 AM
Tyga Performance vs. PLMFG Power Driven - Cheap Full Exhaust Systems Order 2008 - 2012 Ninja 250R Tech Talk 43 November 12th, 2010 02:47 PM
