Old May 13th, 2013, 10:04 PM   #1
deanomyte
Motorcycle(s): 99 honda rebel/ 04 ninjette
replacing starter motor
I have just completed replacing the starter motor, ran into one problem, and this may not even be a problem. While reinstalling the small gear that the starter motor turns, the larger gear (behind the Starter clutch cover) that contacts the smaller gear moved a few teeth backwards. I tried to move the larger gear forward to compensate for the movement, but there was too much resistance.
Is the movement of this larger gear okay?
deanomyte is offline   Reply With Quote
Old May 14th, 2013, 04:51 AM   #2
cuong-nutz
cuong-nutz's Avatar
You should be fine. The starter gear engages one way and spins freely the opposite. You resistance you felt was because it was engaged to turn the motor.
HalfFast Racing Team
Old May 14th, 2013, 11:23 AM   #3
deanomyte
That's kinda what I thought, but just wanted to make sure. Thanks!
Old June 19th, 2013, 09:46 AM   #4
GREY NINJA
Motorcycle(s): 2002 ninja 250
Was it difficult to replace, I need to tackle mine as well
GREY NINJA is offline   Reply With Quote
Old June 20th, 2013, 06:22 PM   #5
deanomyte
not at all. really straight forward, but i did have most of the bike apart already to try to run through it fully. I bought it from an impound yard and it wasn't running due to a trashed carb, and some other issues.
[motorcyclistonline] - Replacing the Starter Drive on a 1997 Harley-Davidson Softail Ninjette Newsbot Motorcycling News 0 October 23rd, 2012 01:50 AM
