June 10th, 2013, 09:38 PM | #1 |
how to time ex250 engine
I have looked everywhere on how to time my 01 ex250. I can't find any information and I'm sorry if I have overlooked it here. A head gasket blown on me and this is my final step towards completion. A link or any help is very much appreciated, thanks.
June 10th, 2013, 09:56 PM | #2 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
No. 2 cylinder on t.d.c., align the inlet cam timing mark with the top surface of the head, align the exhaust cam timing mark with the top surface of the head and you should be good.
Tried to link a pic from photobucket, but it is being a pain again and won't link. Can't seem to link from my computer either, but I am sure you get the idea with the info. Hopefully this image worked, Jiggles, I feel your pain with photobucket. Last futzed with by baxtc1; June 10th, 2013 at 10:19 PM. Reason: Added image |
June 10th, 2013, 11:19 PM | #3 |
Awesome that is exactly what I needed. And I'm guessing cylinder number 2 is on the right side(from sitting on the bike). So turn the flywheel until piston reaches the top correct?
June 11th, 2013, 12:25 AM | #4 |
Yes, no.2 is the right hand side. If you look through the inspection hole on the left side cover, you should see the mark 2T lined up with the mark on the cover.
If you don't have the service manual, I recommend getting a copy, should be able to find a free download with a google search. |
June 11th, 2013, 01:18 AM | #6 |
June 11th, 2013, 08:16 AM | #7 |
Piston reaches top and 2T mark shows twice during one turn of the camshaft, so the cams' relative position shown in the diagram applies to only one of those.
June 11th, 2013, 10:32 AM | #8 | |
June 11th, 2013, 01:45 PM | #9 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
I use a socket to turn the shaft clockwise (while facing left side of bike).
As long as it reads 2T you're fine. It should have a white line on it.... |
June 11th, 2013, 01:48 PM | #10 |
Remove the large plastic cap on the side of the left side cover, you can turn the engine over using a 14mm socket on an extension bar. When tyou have the 2T mark lined up with the notch in the inspection window you can set the camshafts in their correct position.
You really should get a hold of the service manual, Don't just look for Ninja 250, but also look for GPX 250 as it is known to the rest of the world. I could send you a copy, but it is about 34mb. from memory, too big for email. |
June 19th, 2013, 12:53 PM | #11 |
just an update, I put the bike back together and it doesnt run. the compression sounds very weak.
June 19th, 2013, 06:12 PM | #12 |
June 19th, 2013, 10:13 PM | #13 |
Took the spark plug out and wheeled the engine over, and the piston is throwing out water still after replacing the head gasket, so I guess I have a warped head on my hands...
WTB: ex250 engine | jconolty | Items Wanted | 2 | July 9th, 2013 06:34 PM |
Good time to learn engine work? | Jiggles | General Motorcycling Discussion | 47 | September 26th, 2012 08:43 PM |
[crash.net - MotoGP] - Lorenzo to limit track time after engine loss? | Ninjette Newsbot | Motorcycling News | 0 | July 5th, 2012 12:10 PM |
[crash.net - MotoGP] - MotoGP engine change: What happened last time... | Ninjette Newsbot | Motorcycling News | 0 | January 18th, 2012 05:51 AM |
Wtb Engine for 09 EX250 | esi7esi7 | Items Wanted | 13 | November 14th, 2010 03:30 PM |
