Old February 17th, 2019, 06:38 PM   #1
kvgeorge1
Motorcycle(s): EX250J
Replacing turn signal switch 2008 250R
My turn signals are intermittently not working. Turn on the switch and they may/may not work, AND it is getting worse. Someone in another thread mentioned corrosion in the switch and bulb housings. Dielectric grease is easy enough in the housings, but how do I get to the switch? Also, if the switch is bad, how do I replace it? I cannot seem to locate the part online.
kvgeorge1 is offline   Reply With Quote
Old February 17th, 2019, 08:31 PM   #2
Try something like this:
https://www.homedepot.com/p/CRC-QD-1...30-6/202262505
If you're good with your hands, you can disassemble switch and lightly sand corrosion off contact areas. Be careful of little spring size of grain of rice.
Otherwise look in junkyards or call around. You can also use left-hand controls from another bike. Looks identical to stuff off '90s CBR600s.
Old February 17th, 2019, 08:46 PM   #3
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
reminds me of a story....guy askes his buddy if the blinker light is working on the trailer, he responded.....yep, nope, yep, nope...….
[motorcyclistonline] - Turn-Signal Switch Extension Caps For Harley-Davidson Ninjette Newsbot Motorcycling News 0 July 27th, 2016 08:21 AM
Turn signal mounting plate replacing...HELP rph12 1986 - 2007 Ninja 250R Tech Talk 5 March 8th, 2012 09:48 PM
Replacing Turn Signal Bulbs zCasanova 2008 - 2012 Ninja 250R Tech Talk 4 January 1st, 2012 01:06 PM
I need help replacing my turn signal on my ninjette! venmichaels 2008 - 2012 Ninja 250R Tech Talk 8 August 12th, 2011 10:46 PM
