April 21st, 2012, 09:18 AM | #1 |
Carb Sync Screw Replacement?
Hope this is the right section for this.
I was taking apart my carb to be cleaned and "rebuilt", turns out the carb sync screw is missing. Where can I get a replacement of any sort? I don't mind if it's ghetto, as long as it works. |
April 21st, 2012, 09:24 AM | #2 |
http://www.cheapcycleparts.com/model...245-carburetor
I think it's a 4x18 screw? I'm really not sure. Check the parts diagram that I posted above, and then go to the hardware store to get the right sized screw. |
April 22nd, 2012, 08:16 AM | #3 |
I'm looking at that diagram and unfortunately not seeing anything that could be carb sync related. The 4x18 screw looks like it goes somewhere else. =/ I'm probably wrong though.
April 22nd, 2012, 09:22 AM | #4 |
The carb sync screw is the screw in that little bracket that connects the two butterflies. Its job is to make the difference between the two butterflies adjustable.
You're correct, I was wrong. That screw size I posted was not the right one. It was one on the carb caps that holds the choke bracket. The one you was is part # 92001-1998 (BOLT,THROTTLE ADJUST) |
April 22nd, 2012, 11:35 AM | #5 |
It's not a specialty part, just a metric machine screw. Go to a hardware store and get one foe 50 cents
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è. |
April 23rd, 2012, 05:04 PM | #6 |
HA! so turns out the screw hole as stripped. It is infact an m4 screw .70 pitch threading like all the others. I think I bought too long of a screw though lol. Thanks guys.
April 23rd, 2012, 06:22 PM | #7 |
oh no!! Can you replace the bracket so that you can sync your carbs up?
April 24th, 2012, 02:30 AM | #8 |
April 24th, 2012, 07:54 AM | #9 |
FS: Motion Pro Syncpro Carb Tuner (Carb Sync) $60 Shipped | menikmati | Motorcycle-related | 4 | April 8th, 2020 12:39 AM |
please help with carb sync | gantt | 2008 - 2012 Ninja 250R Tech Talk | 30 | August 23rd, 2017 09:31 PM |
Valve adjustment, carb clean, carb sync? | amad1972 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 29th, 2014 09:42 PM |
carb sync | WELLS | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 19th, 2013 08:30 PM |
Help please - carb sync? | nixthewiz | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 7th, 2011 06:37 PM |
