Old July 2nd, 2013, 07:54 PM   #1
djjontran
Motorcycle(s): 2001 ex 250
Spark plugs don't sit all the way down?
Hi everyone. I just got a 250 with a compression leak about a month ago and I've been looking at everyone's posts over the past month or so and it's been awesome!
Anyways I found that there was a frozen valve and it caused the rocker arm to break and caused some damage to the top end so I've replaced it and I've pretty much got everything ready to get the bike running.
So I've installed the NGK spark plugs following the instructions on http://faq.ninja250.org/wiki/Changin...rands_to_avoid and my service manual.
I'm pretty sure I tightened it correctly but when I went to put the coil ignition back on the spark plug it doesn't sit all the way down onto the head cover. I can't remember if it was all the way down when I pulled it out either. Is it supposed to be like that?
djjontran is offline   Reply With Quote
Old July 2nd, 2013, 08:13 PM   #2
Those discs of rubber slide down on the connector of the spark plugs and get flush with the top of the wells.
Old July 2nd, 2013, 08:42 PM   #3
djjontran
Any ideas as to why it's not sitting all the way down? Anyone else have this issue when replacing their plugs?
Old July 2nd, 2013, 09:11 PM   #4
fr1dayn1ght
fr1dayn1ght's Avatar
Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F
happened to me before, one sit all the way down and one didn't so i just took all out again and reinstalled the plug and all good!
maybe you didnt slide it down correctly and it crooked?
fr1dayn1ght is offline   Reply With Quote
Old July 2nd, 2013, 09:36 PM   #5
djjontran
AHHH!!! After playing around with it for a bit I see what you're talking about now. Thank you!!
Old July 3rd, 2013, 07:29 AM   #6
You are welcome
Don't worry much, the well has an opening to drain any water that leaks in.
Old July 3rd, 2013, 11:21 AM   #7
djjontran
You are welcome
Good to know!
Old July 3rd, 2013, 02:16 PM   #8
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
You are welcome
Or oil for that matter.
baxtc1 is offline   Reply With Quote
spark plugs jcsalazar 2008 - 2012 Ninja 250R Tech Talk 11 May 17th, 2015 08:44 AM
spark plugs juanpak87 1986 - 2007 Ninja 250R Tech Talk 12 October 3rd, 2013 09:44 AM
Spark plugs? corksil 2008 - 2012 Ninja 250R Tech Talk 12 October 1st, 2013 11:04 AM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
Spark plugs Betlog 2008 - 2012 Ninja 250R Tech Talk 2 March 1st, 2010 10:59 PM
