#1 |
Head Gasket torn
Had the cover off for valve adjustment. Went to wipe the gasket clean and may be pulled a bit too hard? It's basically a slice right through, breaking the loop the gasket makes.
I'm thinking of using something like a silicone sealant to glue the ends together for the time being. First time I've had this happen in the little time I've been working on the bike, so any guidance would be appreciated. |
#2 |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
Head gasket or Valve cover gasket?
Seeing how you had the cover off for valve adjustment I'm going to guess it's the CYLINDER_HEAD_COVER and not the actual head gasket separating the cylinder head from engine block. Best option is to replace the gasket but some high temperature engine silicone sealer should do the trick until a replacement gasket is obtained. Use something like this Permatex-3 |
#3 |
Yes. Valve cover gasket. Thx
#4 |
You should be scraping off and reapplying the liquid gasket around it anyway.
Head Gasket Replacement | tjkamper | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 13th, 2012 01:58 PM |
head gasket? | NorthKoast | 2008 - 2012 Ninja 250R Tech Talk | 14 | March 10th, 2012 04:01 PM |
Re-use old head gasket ? | Tony B | 1986 - 2007 Ninja 250R Tech Talk | 10 | June 1st, 2011 06:27 AM |
cylinder head cover - gasket | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 7 | March 7th, 2010 04:22 PM |
copper head gasket | Racer x | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 13th, 2010 05:08 PM |
