#1 |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
Removing ignition
Hello,
Quick question. When I was trying to remove the stock ignition switch to replace my triple tree, I came across some odd bolts holding it in place. They appear to be just the screw with the heads cut off or something and I have NO idea how to remove them in order to get the ignition housing off the stock triple clamp. Anyone shed some light on these annoying bolts? Do I have to drill them out? (The aftermarket triple tree has the bolts/bracket to mount the ignition, so there must be a way to remove it?) I couldn't get a good picture of them so I hope this was enough info. Thanks in advance.
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
#2 |
B-Town Ninja
I found my answer thanks to a local friend. Apparently for security reasons, you must drill out those heads in order to remove the ignition.
Removing the carb-without removing airbox? | tuscani451 | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 6th, 2014 05:11 AM |
Removing thermostat | Triple R | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 28th, 2014 08:44 AM |
removing the ignition | the jelly man | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 26th, 2013 06:21 PM |
Removing the flames? | ninja07 | 1986 - 2007 Ninja 250R Farkles | 14 | June 20th, 2012 07:15 AM |
Removing Mirror Bracket (with removing all the fairings) | killermase | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 21st, 2012 11:16 PM |
