Old April 28th, 2014, 04:34 PM   #1
MirinNinja
Motorcycle(s): Ninja 300
Cat delete + slip-on = close to full system?
So I already have a 2Bros slip-on but I want to squeeze a bit more power out of it now that it's a dedicated trackie. Instead of spending money to get a full system, how close to a full system would getting a muffler shop to delete the cat be?
P.S. I will also be adding the stardard air filter upgrade/PC5 to it as well.
MirinNinja is offline   Reply With Quote
Old April 28th, 2014, 04:42 PM   #2
https://www.ninjette.org/forums/showthread.php?t=122220
do it. then run it on a dyno. and post the dyno chart here please.
Old April 28th, 2014, 05:44 PM   #3
misfitsailor
Ninjette Jockey
misfitsailor's Avatar
Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP
Even if you were to cut out the front cat and weld a plain tube there, the diameter of the headers is larger on an aftermarket system. At least it is on my Yoshi.
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?.
misfitsailor is offline   Reply With Quote
Old April 28th, 2014, 06:38 PM   #4
kbryant
Area P
kbryant's Avatar
Hi John - This is a post from July 2013 of essentially that question. Link here to thread -
https://www.ninjette.org/forums/show...777#post718777
Originally Posted by kbryant View Post
We did actually test this. It simply was not worth posting any info about it. No matter how hard we tried, the only significant difference is sound and a slight reduction in radiant heat. We even tested it with the Slip-On. If you can truly feel that slight difference in low-end, you are a human dyno my friend. Honestly, there is more power increase by simply re-mapping.
Exhaust debate: full system vs slip-on theredheadrides 2008 - 2012 Ninja 250R Tech Talk 12 March 11th, 2024 11:46 AM
Area P full race exhaust/jetting/airbox-delete/kleen-air delete.. corksil 2008 - 2012 Ninja 250R Tech Talk 24 January 21st, 2014 07:57 PM
impressions on cat delete jaybo 2013 - 2017 Ninja 300 Tech Talk 12 January 22nd, 2013 09:06 AM
Full system muffler as slip-on? Felipe the Ant 2008 - 2012 Ninja 250R Tech Talk 8 August 19th, 2011 11:51 AM
Slip-on or full exhaust system, hp gain worth the price? JessyBee 2008 - 2012 Ninja 250R Tech Talk 3 January 8th, 2010 03:13 PM
