July 12th, 2014, 02:06 PM | #1 |
Join Date: Jul 2014 Motorcycle(s): 2012 ninja 250R Posts: 6
New member in need of help! - bike won't start
Hello Everyone!
Glad I have joined such an awesome forum. I recently bought my GF a 2012 kawaski ninja 250R. I purchased the bike from an salvage auction yard. The bike was a reported theft, no damages other than the ignition switch. While waiting for an arrival of an ignition swithc(Ebay), my Gf insisted she wanted a flat black color instead of the original lime green. I plasti dipped the bike flat black, while I had the fearing and tank off, the new ignition switch has arrived. I replaced the ignitions switch and after put all the fearing and tank back together. Prior to replacing the ignition switch, I was still able to start the bike with a pair of plier since the ignition switch was tampered with due to the theft. After replacing the ignition switch with a new aftermarket one(same connecter) and put the tank and fearing back after paint, I was unable to start the bike. I have narrowed it down to no spark to the plugs. I already replaced the rectifier thinking it randomly went out. I still don't have spark but fuel is good and flowing to carbs. I need any help possible, I am sick of putting parts and money without having any results. I would appricate any help, comments, troubleshooting, feed back. Thanks, Nawar |
July 12th, 2014, 02:11 PM | #2 |
No start, no spark! Please help...
Hello Everyone!
July 12th, 2014, 02:39 PM | #3 |
/merged
July 12th, 2014, 02:59 PM | #4 | |
It seems that the bike dislikes the new color The problem is always in the things that we have messed with. First, check that there is continuity between the engine and the battery (ground). If not, check that the negative is grounded via naked metal.
July 12th, 2014, 04:23 PM | #5 |
Checked that already, good ground, good battery, but still no spark. I'm thinking it has something to do with the new ignition switch but I am getting power to the coils so I'm guessing that eliminates the ignition problem being a fault?
July 12th, 2014, 04:49 PM | #6 |
Wannabe Reborn
What all did you disconnect when you removed the fairings and tank? I know that removing these are straight forward, but assuming your new ignition is good based on your diagnosis, possibly in the removal of the body work, something else is the issue.
You're sure you have gas flowing? Reinstalling the tank sometimes, I forgot a hose, or I forget that I turned the petcock to a different position for whatever reason. Make sure that you have vacuum at the petcock, opening the diaphragm to allow gas to flow. Sometimes when having the tank removed, the petcock can be damaged depending on how you store it, Did you disconnect any other plugs? obviously the turn signals, but that wouldn't be the issue, unless these are shorted out and caused something whacky to go wrong. Retrace your work on the ignition install, making sure everything is plugged in. When you say won't start, can you be more descriptive: -crank, no fire? -no crank Check fuses, battery, the basics. If I can find the wiring diagram, I'll edit this post with it to try and help.
July 12th, 2014, 04:51 PM | #7 |
Wannabe Reborn
Wiring diagram for 2008-2012 Kawasaki Ninja 250R:
July 13th, 2014, 05:51 AM | #8 | |
Try going back (replacing the old switch) and doing what you did before to see if it will start again. That should tell you. |
July 13th, 2014, 05:56 AM | #9 |
Join Date: May 2013 Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol Posts: 222
Check the connectors to make sure no pins backed out when you connected them.
July 13th, 2014, 08:20 AM | #10 |
The problem is when I replaced the old switch I cut the wires off to get it off easier( I know stupid thinking at the time), no I don't have the old switch to switch out more. Know I thought since I am receiving 12v at both coils then there shouldn't be an issue with the ignition switch?
July 13th, 2014, 08:23 AM | #11 | |
July 13th, 2014, 08:31 AM | #12 | |
Wannabe Reborn
No spark at the wires, how have you verified this? Inline spark detector? When you say you cut wires, which wires specifically? Did you eliminate a a harness?
" If you're here to show off and prove that your crotch rocket is faster than my Harley, you can leave now. " Last futzed with by DmbShn41; July 13th, 2014 at 08:33 AM. Reason: speling |
July 15th, 2014, 08:55 AM | #13 | |
I used an inline spark tester to verify that I have no spark, and the harness I cut belonged to the old ignition switch since I was replacing it and didn't need it no more, I went and cut the wires to remove it easier ( regret doing this now ) |
Help!!!!!!!! - bike won't start | auntymunga | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 18th, 2014 06:54 AM |
Bike Won't Start | momoru | 1986 - 2007 Ninja 250R Tech Talk | 6 | June 18th, 2014 08:34 AM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
bike won't start. tried everything | rabies | 1986 - 2007 Ninja 250R Tech Talk | 17 | September 22nd, 2013 04:46 AM |
Bike won't start | joyinc | 2008 - 2012 Ninja 250R Tech Talk | 21 | May 31st, 2010 09:10 AM |
