August 5th, 2012, 02:04 AM | #1 |
Join Date: Jun 2012 Motorcycle(s): 2010 ninja 250r Posts: 3
from neutral to first and start moving possible WITHOUT clutch?
hey fellow riders.
Recently one of my friends bike clutch cable broke so he had his bike towed. After that since i usually ride in remote roads and all alone i just wondered if it is possible to ride back home (or to the nearest repair center) without using clutch. I know you can ride without out clutch but how about most important part- taking off from a dead stop? I tried to get my bike moving with out clutch by going from neutral to first without clutch but just ended up stalling it. So if its possible how are you supposed to do that? Rev up engine a little bit and then go into first? And how damaging it is for the gears and the clutch? |
August 5th, 2012, 02:45 AM | #2 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
1) hold front brake very hard
2) rev it very hard 3) put it into first very hard now you do a burn out 4) release front brake slowly now you ride, try to avoid city traffic with this 5) replace clutch, clutch cable, rear tire and post video online
I can not be a true player by playing around. |
August 5th, 2012, 06:49 AM | #3 |
From stop, start engine in gear, hard on starter but starter cheaper to replace than transmission. Better yet, buy spare cable and install in parallel with existing one, that way if cable breaks you can fix it right then. No fuss, no muss...
August 5th, 2012, 07:49 AM | #4 | |
probably just use some velcro cable ties to hold them together. |
August 5th, 2012, 08:12 AM | #5 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
The OP's question about rolling the bike and slipping it into first gear without the clutch would work. From there a good rider can pretty easily shift gears without the clutch. For me personally , I use my clutch only while moving from a dead stop and while downshifting. Upshifting without the clutch is easy, downshifting without the clutch is more sensitive to correct rpm and timing but doable.
August 5th, 2012, 08:36 AM | #6 |
Crab walking the bike some will allow you to engage first gear, or you can push-run-jump on the bike while in Neutral.
How exactly do you do clutch-less downshift?
August 5th, 2012, 08:48 AM | #7 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
Couldn't you just roll your bike to the top of the nearest slope, sit on it, start rolling down the hill, start the bike (while in neutral) and then slip it into first while rolling?
The burn out idea sounds fun but sketchy! |
August 5th, 2012, 11:46 AM | #8 |
Jigglin' your Jiglets
MOTM - Apr '13
When coming to a stop just let the bike stall then shift to neutral. Start the bike and push forward with your legs to get a bit of speed, rev up just a little bit and drop it into first and prepare for the jolt. Then clutch less up shift when you need to but stay in the lowest gear possible since clutch less downshifting would be difficult if you needed to do it. So for example if you're going 50mph stay in 3rd
You can also practice this by just not using your clutch
August 5th, 2012, 11:49 AM | #9 |
August 5th, 2012, 11:55 AM | #10 | |
August 5th, 2012, 12:04 PM | #11 | |
How can you blip the throttle if the engine and rear wheel are solidly connected? As I understand it, blip means rev the engine up while disengaged form the transmission and rear wheel. Just asking, as I have never done it.
August 5th, 2012, 12:23 PM | #12 | |
during a normal downshift you would match revs with the blip, so the bike wont become unsettled. you're doing the same thing in this case, except with no clutch you have to be quicker and know how much to open the throttle. i'm far from an expert on doing this but it seems to work well in the lower rpm ranges 4000-6000. lightly use the brakes until you reach this range of rpms. press on the shift lever, and open the throttle quickly. it should pop unto a lower gear. using the lower rpm range you almost always over throttle, and match revs cleanly. if you don't use enough throttle or don't hold the rpms, the bike will become very choppy. |
August 5th, 2012, 12:34 PM | #13 |
Thanks!
It sounds very interesting and I don't really understand how the transmission works while that happens. I will try it as you have explained it.
August 5th, 2012, 12:37 PM | #14 |
MOTM - Apr '13
I think avoiding clutchless down shifting would be easier right? Just let it stall in gear and then switch to neutral. You think starting in first would be easier? Maybe I'll go try it today
August 5th, 2012, 02:40 PM | #15 |
Join Date: Mar 2012 Motorcycle(s): 2008 Candy Plasma Blue Ninja 250R Posts: 58
Won't the clutch sensor not let the bike crank in gear? Is the clutch sensor going off of the clutch or the clutch lever?
August 5th, 2012, 05:20 PM | #17 |
That is a very good point: Does anything need to be done to the lever in order to keep it in place while starting with a broken clutch cable?
Motofool .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; August 5th, 2012 at 06:30 PM. |
August 5th, 2012, 06:17 PM | #18 |
Join Date: Jun 2012 Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F Posts: 534
When my friend's dirt bike we used to beat on lost its clutch cable (which we STILL haven't replaced some years later) we got it moving by pushing it, jamming it in gear and go! I think everyone should ride my friend's bike. It will teach you how to get by without such important items. Like suspension, or a clutch cable, or brakes. Literally, it has no brakes. Only way to slow down is engine braking. Good thing it's only a KLX 125 and not some power house that you would actually need the brakes on.
How exactly does neutral work? | MrAtom | 1986 - 2007 Ninja 250R Tech Talk | 17 | December 29th, 2014 02:24 PM |
Racing in Neutral | Hero Danny | General Motorcycling Discussion | 28 | August 20th, 2014 06:24 PM |
No headlight, no neutral indicator, no start | anters | 2008 - 2012 Ninja 250R Tech Talk | 6 | December 31st, 2013 09:48 AM |
2007 won't start, not even getting neutral or oil warning lights! | davidfriend | 1986 - 2007 Ninja 250R Tech Talk | 13 | May 6th, 2011 09:51 PM |
False neutral | SteveL | 2008 - 2012 Ninja 250R Tech Talk | 6 | March 26th, 2009 09:14 AM |
