Old December 22nd, 2011, 09:29 PM   #1
setasai
setasai's Avatar
What are the thickest grips?
Can anybody provide input on the thickest grips? I have relatively large hands and the stock grips are wayyyyy too small. I've even tried progrips 719 and they're about the same size.
I'm considering trying out Progrips 842 cruiser grips.
http://www.motorcycle-superstore.com...iser-Grip.aspx
2009 Ninja 250R SE Green Sport Touring Style:
ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket
Old December 22nd, 2011, 09:34 PM   #2
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
The Driven D3s are pretty thick.. Not sure how they compare to those or the others you've tried.
My suggestion would be to somehow mod your bars to accept 1" grips or something.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old December 23rd, 2011, 06:14 AM   #3
DaBlue1
DaBlue1's Avatar
Bikemaster http://www.motorcycle-superstore.com...WT.ac=SLI_SERP makes some foam grips which are thick and cushy, but I felt they were too thick with winter gloves. So I stuck with the Pro-gel grips.
Old December 23rd, 2011, 09:54 AM   #4
Cazper
ninjaholic
Cazper's Avatar
I don't actually have a solution... just a statement. I personally don't actually grip all the way around the grips... I usually just rest my hands on the bars. Even the throttle I don't wrap my hand completely around.
So here's my question... is it a problem of firmly gripping the grips? Also, how long do you typically try to do that?
09' SE Ninja 250R
$2,547.83
Old December 23rd, 2011, 07:00 PM   #5
setasai
setasai's Avatar
Heh same. I dont grip it all the way around either but I put grip puppies on and loved the larger size. It made it much more relaxed of the grip. I find that even when I'm just trying to accelerate, with narrow grips, I feel less "in tune" with the throttle.
Thanks for the tip though. All riders should conciously keep in mind to use loose grips but my issue is truely the size.
The reason why I dont like grip puppies is because it is very insulating for my heated grips and so I think if it was thicker but not "grip puppies + stock grip" thick, I might have a good middle ground.
What's the difference between off-road grips and street grips? psych0hans 2008 - 2012 Ninja 250R Farkles 3 April 12th, 2014 07:01 AM
DIY - Hot Grips Heated Grips Install NathanF 2008 - 2012 Ninja 250R Farkles 26 January 23rd, 2014 03:37 PM
[motorcyclistonline] - Spider Grips Slim Line SLR Grips | MC Tested Ninjette Newsbot Motorcycling News 0 May 2nd, 2013 04:10 PM
