Old July 15th, 2013, 07:06 PM   #1
ubxssangz
2009 ninja 250 cct
Hi,
out of curiosity. Can I rest the cct by just removing the 10mm bolt in the middle, retract the metal stick then let go? Or MUST I remove the whole cct?
ubxssangz is offline   Reply With Quote
Old July 15th, 2013, 07:08 PM   #2
krolinked
Nerd
krolinked's Avatar
Yes
You can reset it without removing it. But it should automatically take up the slack. Or is it too tight that is the problem?
Old July 15th, 2013, 07:31 PM   #3
ubxssangz
I'm trying to reset due to a ticking sound
Old July 16th, 2013, 08:45 AM   #4
ubxssangz
Thanks krolin for your feedbad!!
Everyone else agree's that i can reset the cct by just removing the 10mm bolt in the middle and not removing the whole thing?
Old July 16th, 2013, 09:35 AM   #5
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
Go APE
I had the exact same problems. I would try and reset it and it would work and then it would fail.
However, to properly reset it, you need to remove the 10mm bolt and use a small flathead screwdriver (like a jeweler's or a bit with a small thumb ratchet) that you can wind up to bring it back and then release and it should reset.
Since I do a lot of valve clearance checks and I HATE the OEM cam chain tensioner, I just caved and spent $60 on an APE manual cam chain tensioner...much easier to use.
To set it, just loosen the locknut and turn the bolt to bring the tensioner back. Install the tensioner onto the engine. Then use your hand (NO TOOLS) and turn the center bolt until you cannot turn it anymore. Loosen it by hand a 1/4 turn. Tighten the locknut down using a 5/8" open end wrench. Start it up. If there is noise, adjust as needed. If no noise, then go for a test ride and make sure there isn't anymore noise.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old July 16th, 2013, 10:53 AM   #6
ubxssangz
so you don't have to remove the whole cct by removing the 2 8mm side bolts?
Old July 16th, 2013, 02:42 PM   #7
krolinked
Nerd
krolinked's Avatar
If it is working properly, No you don't need to. If its broken, then you need a new one.
Old July 16th, 2013, 04:24 PM   #8
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
I have the ticking noise as well and decided to order the APE Manual CCT. While waiting for the new one to arrive I might try to reset the factory one this weekend.
LoD575 is offline   Reply With Quote
Old July 16th, 2013, 07:28 PM   #9
ubxssangz
Mine sound like an oven pilot light. Are we talking about the same sound?
Old July 17th, 2013, 06:56 AM   #10
DaBlue1
DaBlue1's Avatar
I highly doubt they are. The tick you have is abnormal and if they have not seen or read your other thread, they won't exactly know what you are dealing with.
Old July 17th, 2013, 06:57 AM   #11
ubxssangz
Meaning that this is not a cct problem?
Does anyone have any guidelines of how to remove the engine?
Old July 17th, 2013, 07:12 AM   #12
DaBlue1
DaBlue1's Avatar
Exactly.
This is what a good running bike sounds like with the cam chain guide (part of the CCT) missing. Sounds nothing like yours.
Old July 17th, 2013, 02:38 PM   #13
ubxssangz
Exactly.
that ticking is actually one of the 2 sounds that i have.
fyi, I tried reseting the cct by only unscrewing the middle 10mm bolt, retracting it and letting go. Not sure if it has enough tension though. Kind of felt week when I removed the screw driver.
Old July 17th, 2013, 04:11 PM   #14
LoD575
LoD575's Avatar
The tick I have is a very light ticking noise very similar to the first video DaBlue1 posted. It sounds nothing like a rod knock/piston slap/valve piston impact.
Where to get a Manual CCT? Graugaard 2008 - 2012 Ninja 250R Tech Talk 17 August 21st, 2013 11:59 AM
WTB: new or used CCT NinjaBoyEddy Items Wanted 8 January 19th, 2013 07:31 PM
CCT Removal menikmati 2008 - 2012 Ninja 250R Tech Talk 5 August 3rd, 2012 01:51 PM
Resetting CCT while on the bike Broc 2008 - 2012 Ninja 250R Tech Talk 13 March 8th, 2012 03:07 PM
is it my cct? alex.s 2008 - 2012 Ninja 250R Tech Talk 3 November 8th, 2011 09:40 AM
