September 14th, 2013, 06:53 PM | #1 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
Did I hurt my suspension?
It's hard to explain, but I was riding around today, and at low-parking lot speeds, my rear tire seemed to be acting strange. It wasn't slipping, but it felt like it wanted to.
I know that probably doesn't make any sense, but maybe it was caused by something that happened yesterday. Last night I was downshifting thru the gears, slowing down before a left hand turn. I thought I was shifting from 3rd to 2nd; but turns out I was actually already in 2nd, so I shifted into 1st at a relatively fast speed. Can this screw up my suspension? |
September 14th, 2013, 07:42 PM | #2 |
No the suspension, but it could make the shaft slide on the swingarm guides and create some tires' misalignment and maybe chain slack.
September 14th, 2013, 09:44 PM | #3 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Did you check the pressure of the rear tire?
September 14th, 2013, 09:58 PM | #4 |
Your face
September 14th, 2013, 10:45 PM | #5 |
Fast-Guy wannabe
MOTM - Jan '13
Your pressure could be a couple psi higher buts that's nothing you'll ever feel. It could just be some newbish gremlins in your head but it's worth checking your rear axle alignment. just check both side to make sure the two lines match up tp the same swingarm marks.
By the way your description of what your feeling totally sucks so it's kinda hard to give a better suggestion. |
September 15th, 2013, 05:51 AM | #6 |
Join Date: May 2012 Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally Posts: 384
Maybe you collected something greasy or slippery on your back tire...
Did it happened again? Was it when you were turning? |
September 15th, 2013, 05:03 PM | #7 |
Your face
So I did the string test for tire alignment, and I'm fairly certain I did it correctly. If I did, it looks like I in fact have some alignment issues.
You can see how cocked the fender is towards the right when the strings are evened out on both sides of the front tire. So in conclusion, I must have knocked off the alignment when overrevved to 1st..? |
September 15th, 2013, 06:17 PM | #8 |
Overrevving isn't going to affect alignment, unless your axle bolt was incredibly loose, but then it probably would have moved for a variety of other reasons as well. That said, it does look like your rear tire may be out of alignment. That DIY describes how to get things straight, and then make sure to tighten things up and recheck alignment when done.
September 15th, 2013, 06:59 PM | #9 | |
Your face
In the pic below, is the arrow pointing at the threads I'm supposed to count? It's hard to see, but the swingarm notches aren't quite even. But I've been reading that these notches are inaccurate anyway, rendering them close to pointless?? |
September 15th, 2013, 07:11 PM | #10 |
Your face
Wait, that doesn't make sense.
The bolt threads I'm supposed to count is underneath this part....yes? |
September 15th, 2013, 07:35 PM | #11 |
That chain is screaming for some fluids !!!
Did you check if some weight of the rear tire is missing? I never go by those marks or threads, proper alignment should be done comparing one tire to the other.
September 15th, 2013, 07:39 PM | #12 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
Line up the notches. I bet weird feeling goes away
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
September 15th, 2013, 07:41 PM | #13 |
Your face
September 15th, 2013, 07:44 PM | #14 | |
The O-rings should be covered by some kind of lubricant.................. always. Otherwise, the links may kink respect to the other and give some weird feeling as well. I lubricate my chain after every tank fill up.
September 15th, 2013, 08:38 PM | #15 | |
Your face
September 15th, 2013, 11:19 PM | #16 |
Scroll down a bit in that thread; all the ones that matter are still there.
September 15th, 2013, 11:20 PM | #17 |
Yes.
September 16th, 2013, 12:37 AM | #18 |
Freedom for Germany
This is a good way to measure (picture doesn't show the Ninja).
September 16th, 2013, 01:38 AM | #19 |
Jigglin' your Jiglets
MOTM - Apr '13
Ninjette quote of the month
September 16th, 2013, 10:12 AM | #20 |
Your face
September 16th, 2013, 10:22 AM | #21 |
Fast-Guy wannabe
MOTM - Jan '13
September 16th, 2013, 10:30 AM | #22 |
Your face
I love being a n00b
September 16th, 2013, 12:10 PM | #23 |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
Check your front tire pressure, too. A low front tire will make the bike feel squirrely, which feels like a slipping rear tire.
[motorcycle.com] - K-Tech Suspension Announces Classic Custom Suspension | Ninjette Newsbot | Motorcycling News | 0 | January 7th, 2015 09:40 PM |
[roadracingworld.com] - JRi Shocks And GP Suspension Team Up To Offer Suspension Pack | Ninjette Newsbot | Motorcycling News | 0 | November 14th, 2012 01:40 PM |
[roadracingworld.com] - STM Suspension Holding Suspension Seminar June 25 In Colorado | Ninjette Newsbot | Motorcycling News | 0 | June 21st, 2011 10:10 AM |
I hurt myself. | tapdiggy | General Motorcycling Discussion | 12 | December 15th, 2010 07:34 AM |
[superbikeplanet.com] - RIP: Harry Hurt of The Hurt Report | Ninjette Newsbot | Motorcycling News | 0 | December 1st, 2009 01:10 PM |
