Old March 7th, 2017, 06:40 PM   #1
Ralgha
Ralgha's Avatar
Removing Camshaft Caps
I'm trying to remove the camshaft caps to adjust my valves and they won't budge, it's like they're welded in place. Same with the piece the chain guide bolts into. I've removed four bolts from each cap, and the four bolts in the chain guide. Did I miss something? There's zero movement in the caps, not the slightest wiggle. Any help is appreciated.
Old March 7th, 2017, 08:52 PM   #2
Ralgha
Ralgha's Avatar
Solved it. The piece that the chain guide bolts to had loosened unevenly. I screwed one of the bolts back into it until it snapped back level, then everything pulled off pretty easily.
Last futzed with by Ralgha; March 7th, 2017 at 11:11 PM.
Old March 7th, 2017, 09:56 PM   #3
Good job!
Removing the carb-without removing airbox? tuscani451 2008 - 2012 Ninja 250R Tech Talk 10 July 6th, 2014 05:11 AM
camshaft profiles micoulisninja 2008 - 2012 Ninja 250R Tech Talk 30 February 12th, 2014 04:01 AM
Removing Mirror Bracket (with removing all the fairings) killermase 2008 - 2012 Ninja 250R Tech Talk 11 May 21st, 2012 11:16 PM
Intake Camshaft jpatt87 Items Wanted 14 January 19th, 2012 08:55 AM
DIY- Removing Fork Caps/Pistons and Springs Zombiphone 2008 - 2012 Ninja 250R Tech Talk 15 October 7th, 2011 12:23 AM
