March 15th, 2017, 06:01 PM | #1 |
Speedometer Cable vs Magnets
Just put a Koso gauge on and used the adapter on the stock speedometer cable. Is there any reason to use the magnets and pickup instead? What are the pros and cons aside from the extra work of installing?
March 15th, 2017, 06:08 PM | #2 |
The only one I can think of is you don't depend on a speedometer cable, which is subject to wear and breakage, if you use a magnetic pickup on the wheel, or rear sprocket, etc. Are you saying you have a Koso speedometer or multifunction unit, and you also have the stock speedometer still functioning?
March 15th, 2017, 06:09 PM | #3 |
Join Date: Jun 2013 Motorcycle(s): 2010 Ninja 250 Posts: 596
Removing the speedo hardware will reduce power-robbing friction.
Magnetic pickup speedo will be more accurate when set up correctly. Speedo cable is another point of mechanical failure. Using magnets can be finicky to set up first and they will not provide much resolution at low speeds. I think the pros outweigh the cons. |
March 15th, 2017, 06:55 PM | #4 |
I got the plug and play kit, which provides an adapter that screws into the stock cable and generates a digital signal for the gauge, that's what I hooked up for now.
Any ideas on a good way to plug the hole by the wheel hub if I remove the stock cable? |
March 16th, 2017, 05:41 PM | #5 | |
Personally, if I already had a cable adapter on a bike that came with a cable stock, I'd just leave it at that. There are advantages to a magnetic pickup, but I haven't been too impressed with the setup of addon magnets/sensors I've seen.
March 17th, 2017, 07:14 AM | #6 |
I just left the adapter on it, decided I didn't want to bother messing around with the magnets and pickup.
Speedometer/Odometer Cable | kennetht | 2008 - 2012 Ninja 250R Tech Talk | 19 | May 5th, 2014 09:55 AM |
Speedometer cable help! | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 98 | November 21st, 2012 12:05 PM |
speedometer cable.... | Stingray1000 | 1986 - 2007 Ninja 250R Tech Talk | 8 | October 10th, 2012 09:14 AM |
Speedometer cable | kohkae | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 13th, 2012 09:57 PM |
Speedometer Cable | indr | 2008 - 2012 Ninja 250R Tech Talk | 2 | December 24th, 2010 05:02 PM |
