March 7th, 2017, 06:40 PM | #1 |
Join Date: Oct 2013 Motorcycle(s): Ninja 250R, Tiger 800 XRT Posts: 828
Removing Camshaft Caps
I'm trying to remove the camshaft caps to adjust my valves and they won't budge, it's like they're welded in place. Same with the piece the chain guide bolts into. I've removed four bolts from each cap, and the four bolts in the chain guide. Did I miss something? There's zero movement in the caps, not the slightest wiggle. Any help is appreciated.
March 7th, 2017, 08:52 PM | #2 |
Solved it. The piece that the chain guide bolts to had loosened unevenly. I screwed one of the bolts back into it until it snapped back level, then everything pulled off pretty easily.
Last futzed with by Ralgha; March 7th, 2017 at 11:11 PM. |
March 7th, 2017, 09:56 PM | #3 |
Good job!
Removing the carb-without removing airbox? | tuscani451 | 2008 - 2012 Ninja 250R Tech Talk | 10 | July 6th, 2014 05:11 AM |
camshaft profiles | micoulisninja | 2008 - 2012 Ninja 250R Tech Talk | 30 | February 12th, 2014 04:01 AM |
Removing Mirror Bracket (with removing all the fairings) | killermase | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 21st, 2012 11:16 PM |
Intake Camshaft | jpatt87 | Items Wanted | 14 | January 19th, 2012 08:55 AM |
DIY- Removing Fork Caps/Pistons and Springs | Zombiphone | 2008 - 2012 Ninja 250R Tech Talk | 15 | October 7th, 2011 12:23 AM |
