January 11th, 2009, 01:36 PM | #1 |
Bulb Types?
So, I am looking into replacing the bulbs in my turn signals and brake lights to LED while making another beacon for the mothership like Vex's and adding some HIDs in the front. The problem is, partly I'm lazy and don't want to dig through the mess in the garage to get to my manual(storing a friend's bike makes it a little tight sometimes.... *cough* Nick *cough*), and partly because I want other folks to have a nice one-stop resource to find all the types as well.
So without further ado, this is what I have found various places, as to what I think the bulb types for our 250s are.... Head lamps 12 volts, 55 watts, Type H7 Turn signals BAU15s Brake light Type 1157 (thanks dnaL0R), which is a two-filament bulb (first filament for running light, second filament when brakes are applied). Can anyone confirm if this info is correct? Would these be white bulbs and the color comes from the housing? Thanks for humoring me on a cold, dreary Sunday afternoon Last futzed with by noche_caliente; January 15th, 2009 at 09:18 PM. Reason: to add flasher bulb pics |
January 11th, 2009, 04:20 PM | #2 |
I can confirm the headlight and tailight bulbs are correct.
you might want add to your list the cluster bulbs. |
January 14th, 2009, 07:33 PM | #3 |
so after investigating a little more, I've found more info on the signal bulbs. They are a type BAU15s. I found this post on a Vespa forum: http://www.modernvespa.com/forum/topic87.html
It's a very similar bulb, and the base type is the same with most of the indecipherable number on it the same. So - if you are looking to keep the stock housings, but replace the bulbs with LED, then you need bulbs of the BAU15s type. It's a bayonet-style connector that has the terminals at 150* instead of the standard 180*. |
May 27th, 2009, 05:24 PM | #4 |
The Grand Royal
Join Date: Dec 2008 Motorcycle(s): 2009 Ninja 250R Posts: 258
I have a Custom Dynamics Red 1157 RL1157-32-R en route, $14.50 shipped.
I'll report on brightness of this LED tail from stock. |
October 22nd, 2009, 02:18 PM | #5 |
Tagged... I'm wondering why the service manual doesn't mention "H7" anywhere? Huh.
October 22nd, 2009, 02:22 PM | #6 | |
... approximately 5 months later.... Well? How'd it work for you? I'm interested because during my summer tour my tail light burned out and I only found out because I got off the bike to take a picture near sunset. I want the longevity/reliability of LEDs. |
October 22nd, 2009, 04:14 PM | #7 |
October 24th, 2009, 05:26 AM | #8 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
October 28th, 2009, 04:20 PM | #9 |
Results are in for the 1157 LED
I received the LED 1157 tail/brake light today. Took pictures of bike with the factory bulb installed with tail light and then brake light. I then replaced the bulb with the LED version and again repeated the same pictures. That's when I noticed one problem. I have the no-cut brake modulator installed. It works great with the factory bulb, but will only work ONE time with the LED bulb. You have to turn the ignition key off and back on, in order to get the LED bulb to modulate again....for one time!
I'm not going to post the pictures, as the factory bulb is brighter in both modes, i.e. tail and brake. Yes, I reinstalled the factory 1157 bulb. |
October 28th, 2009, 05:22 PM | #10 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250 (Blue!) Posts: 488
Bummer
One small thing -- you can't tell from a picture which light is brighter unless you have manually set all of your exposure controls. Not that it really matters in this case. |
October 29th, 2009, 03:33 AM | #11 |
I haven't even uploaded the pics from my camera. I did the old IEBEYEBALL evaluation.
November 8th, 2009, 05:03 PM | #12 |
December 19th, 2009, 11:02 AM | #13 |
Join Date: Dec 2008 Motorcycle(s): ninja 250r Posts: 371
If you are looking for the gauge cluster lights the part# is kha37L and hey are a 12v 3.4 w wedge bulb
08 250R: sportisi VR full exhaust, Dynojet, custom seat, kleen air rmvd, rim tape, grips, fender chop,zg db windscreen,k&n air filter,15t front sprocket,sportisi-usa clipons,solo seat cowl |
December 19th, 2009, 12:14 PM | #14 |
I picked up some new bulbs B/C one of mine went out I found that you can use any 194 bulb B or A. i went with a blue light a few pick
December 19th, 2009, 12:15 PM | #15 |
ooh and cost about 5 bucks for 4 lights
December 19th, 2009, 01:37 PM | #16 |
I like that blue on the dash!
thanks for the info. |
December 19th, 2009, 01:43 PM | #17 |
thanks
December 19th, 2009, 02:07 PM | #18 |
Join Date: Apr 2009 Motorcycle(s): '04 sv650s Posts: 438
Putting LEDS in stock housing will be a downgrade - as far as being visible go. They aren't as flashy in daytime as incadescent.
There's 2 types of people in this world, those who complain and those who act. |
December 19th, 2009, 02:31 PM | #19 |
December 19th, 2009, 02:46 PM | #20 |
nope I mean the flashers/brake
May 18th, 2010, 12:27 AM | #21 |
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250 "Wasabi", 82 Yamaha xj650j Posts: A lot.
BBBUUUUMMMPPP
Turn signal bulbs!!!!! WHY? These bulbs seem to be ridiculously rare. Why....did Kawi go this route? I am truely happy with the stock housing. However I want a local car store option for replacing a blown turn signal bulb. Not a special order hastle. It's easier to replace the tires on this bike than it is a turn signal! Kawi gloated they went to 17" tires to make rubber options on this bike better, yet they went all vespa on us with the signal bulbs!!! Anyone have a link to a DIY to modify the signal sockets? OR Have a link for clear or silverized turn signal replacements. Again..I like the stock housings but cant stand the fried egg effect. I'm not set on LEDs for this one either. Thanks in advance.
May 18th, 2010, 12:40 AM | #22 |
take the stock yellow bulbs out and spray them with a light coat of silver paint. the bulb will look silver when it's off and glow yellow once it's turned on.
gets rid of the egg yolk turn signals. |
May 18th, 2010, 08:40 AM | #23 |
Thanks for the reply kaykay and it looks good, but how much light is lost because of the paint?
I would also like to do a DRL mod in the future and dont want to worry about how well the paint would hold up with the bulbs always on. Paint does seem to be my only other option next to finding a clear or silverized 180deg bulb and filing off one of the pins.
May 18th, 2010, 10:46 AM | #24 |
I haven't had any heat related problems with the silver paint. If you're concerned, use a high temp silver paint for engine parts.
The light output seems the same to me... there is no noticeable degraded output. Use a light coat of paint, just heavy enough so the yellow color disappears. It doesn't take much paint at all. |
May 18th, 2010, 10:56 AM | #25 |
Join Date: Feb 2010 Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1 Posts: 133
It took me 5 min a socket to make it a 180 pin config. I used a Dremel w/ 1/8 carbide burr, no more worries. Stupid 150 bulbs!
May 18th, 2010, 10:57 AM | #26 |
what bulbs are you using now?
May 18th, 2010, 05:08 PM | #27 |
Join Date: May 2010 Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black Posts: 455
Thanks for the posting OP. This was exactly what I was looking for!!!
Got a question though, are the turn signals the same bulbs as PY21W? |
May 18th, 2010, 10:50 PM | #28 |
I have stock bulbs now but these are on order from superbrightleds.com:
(4) 67-A15 (1) CF12ANL-01 flasher. I wanted to make sure the sockets could be modded before I ordered the bulbs. If these aren't bright enough I might have to make my own LED arrays on a standard bulb base. Here's pics of the mod before & after: |
May 18th, 2010, 11:06 PM | #29 | ||
Im guessing a 12v R10W BA15s which doesnt seem to be common either. the vespa site mention that an 1156 bulb should drop in but..... I Dunno bout that one!
May 19th, 2010, 01:30 PM | #30 |
Can anyone confirm what the stock license plate bulb is? Can you swap with a 194 led bulb?
'10 Ninja 250R SE Red/Blk Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents |
May 20th, 2010, 12:36 PM | #31 |
It's an 1156 socket for the plate illuminator, or at least that's the standard bulb size/socket that fit when my OEM burned out. I'm 99.9% sure a 194 won't work in that socket without some kind of adaptor or modification to the bulb.
Replaced my OEM with a 67-x15 from www.superbrightleds.com. It's not as bright as I'd have liked it to be, but it's brighter/whiter than stock and not too shabby for lighting from LEDs that are facing 90 degrees from the target (bulbs are directed ~level w/ ground, lens is below bulb).
May 20th, 2010, 01:23 PM | #32 |
Join Date: Jun 2009 Motorcycle(s): 08 Candy Plasma Blue Posts: 125
mmm just like my VW... blue gauges and a red needle
Real HIP HOP is not on the radio | SHIFT the MC | 3,100 Channel Views & Rising | Updated April 18,2010 |
May 21st, 2010, 04:10 PM | #33 |
Thanks, I went with a 1156 led bulb for my license plate. Hopefully it will come soon.
Also, I'm not sure if this is correct or not, but I think you can use a 7507 BAU15S LED bulb in our turn signals. I bought some of those also and will test them out and let you guys know if they work/fit or not. Wish me luck... just waiting on shipping now. These were on back order, so it may take some time for me to get them.
May 22nd, 2010, 07:34 PM | #34 |
The superbrightleds.com 67-A15 amber bulbs & CF12ANL-01 flasher came today. Bulbs went right in the modified turn-signal sockets and fit perfect length-wise. Light might be 5-8% less but the instant-on flash makes up for it by being more eye-catching. No more egg-yolk look. The flasher plugs in directly but has no mounting bracket.double-faced tape and a ty-wrap to the stock bracket takes care of that.
June 2nd, 2010, 10:16 AM | #35 | |
June 2nd, 2010, 02:41 PM | #36 |
OK I'll get the camera out
June 11th, 2010, 11:12 AM | #37 |
Has anyone been able to change the turn signals to leds without having to mod anything? If so, where did you purchase your leds? I bought some, but they are way too long to fit in the housing. I got 7507 BAU15s LEDs for V-Leds.com
July 19th, 2010, 01:58 PM | #38 |
Anyone order more stock turn signal bulbs than they needed? It looks like Kawi sells them in a 4-pack.
July 19th, 2010, 02:31 PM | #39 |
OK, I must be doing something totally wrong, but I feel like the bulb is going to shatter and shred my thumb if I try any harder. HOW THE HECK DO YOU REMOVE THEM FROM THE REFLECTOR/SOCKET? I tried push and turn, I tried pull and turn, I tried just turn, nothing. The bulb wiggles a bit when I twist back and forth, so I know it's not stuck to the socket. Even so, when it comes time to twist it into position, the little pegs just stay put and will not twist to a point where they slide out. I feel a blister forming on my thumb from the friction as it slips while I apply tight compression+turning. Any tighter and I feel that I'd shatter the bulb/shred my thumb. What would someone do if the bulb were broken?! Somehow, I doubt the potato trick would help.
Last futzed with by CZroe; July 19th, 2010 at 05:29 PM. |
July 19th, 2010, 06:50 PM | #40 |
Press and turn counterclockwise is indeed how the sockets are designed; just checked on my stock housings.
I presume you've pulled the reflector/socket out of the black housing? Might try getting a screwdriver behind it (through the back of the socket) once you've turned it as far as it'll go to help push it out. Suppose it's possible the bulb is getting jammed on extra plastic in the housing. As a last resort, you could try just breaking the bulb (since it's hosed anyway) and using pliers to get the housing out. Sorry to hear you're having issues, mine have always just fallen out once I've gotten 'em turned enough. Suppose there's some truth to the 'How many X does it take to change a lightbulb' jokes...
Light bulb and Gauge bulb options | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 11 | August 21st, 2014 10:06 AM |
Does dead taillight bulb affect the license plate bulb? | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 3rd, 2013 06:05 AM |
WTB: Replacement bulb. Upgraded to HID? Sell me your old bulb! | CZroe | Items Wanted | 7 | October 25th, 2009 03:58 PM |
There are two types of riders... | LazinCajun | General Motorcycling Discussion | 13 | October 7th, 2009 01:42 PM |
Gasoline types | CrzyFstMnM | 2008 - 2012 Ninja 250R Tech Talk | 24 | April 3rd, 2009 07:36 AM |
