April 13th, 2013, 08:01 PM | #41 |
Even though you don't drive WOT a lot. Take a look at Gearing Commander, plug in/change the gearing to see how your speed can change with different rpm speeds.
April 13th, 2013, 08:04 PM | #42 |
April 13th, 2013, 08:20 PM | #43 |
Just ordered the pipercross from sportbiketrackgear, the pic they have on the site looks kind of weird. Is that the actual filter or just a stock photo for pipercross?
Once I put in the new filter will i likely have to go back to the 98 jet? |
April 14th, 2013, 07:14 AM | #44 | |
Hopefully you won't have too. |
April 14th, 2013, 10:33 AM | #45 |
April 14th, 2013, 10:43 AM | #46 |
April 14th, 2013, 10:58 AM | #47 |
weird I guess i should have never rejetted with the new exhaust? I also noticed when i started the bike cold it was actually low rpm and i needed to use the choke, i havent really used the choke ever because my idle was never below 1k even cold
April 14th, 2013, 11:20 AM | #48 | |
http://www.ninjette.org/forums/showt...ect#post664048 "One of our industry's most insidious misconceptions, ................ is the idea that installing an aftermarket exhaust system necessarily requires the changing of carburetor jetting. It just isn't so. Not every aftermarket exhaust affects carburetion. A number of complex physical things are going on in an exhaust system..........The fact is, much of the performance increase resulting from replacing the exhaust and the subsequent carburetor rejetting is due simply to the rejetting, not the exhaust...........That's right, the run-of-the-mill "implied performance" type exhaust frequently requires no jetting change at all! In many cases, the stock jet will do just fine. " The porcelain ends of those spark plugs are way too white and clean to show any engine condition; they may have not been working for long in there. Kudos to Blue and Chone!!!
April 14th, 2013, 01:18 PM | #49 | |
How's the bike feel during partial throttle roll-ons and roll-offs? If it feels smooth there, you're pretty much done with the jetting changes. |
April 14th, 2013, 02:22 PM | #50 |
Rolls ons feel like it could use improvement, I'm hoping with the new filter i get to replace the stock one will make a difference. this filter is 4 years old and has 9.5k miles on it so it needs a change
April 14th, 2013, 04:01 PM | #51 |
Kawasaki recommends replacement at 2 years. the stock filter is pretty dense with tiny, tiny holes and will compress over time. A new filter should help.
Rich or Lean | eulark | 1986 - 2007 Ninja 250R Tech Talk | 6 | May 11th, 2014 06:48 PM |
lean or rich condition | vmax | 2008 - 2012 Ninja 250R Tech Talk | 4 | December 23rd, 2012 09:20 AM |
lean/rich test | Confuzshuz | 2008 - 2012 Ninja 250R Tech Talk | 4 | August 26th, 2012 09:30 PM |
Too rich or too lean | rich3389 | 1986 - 2007 Ninja 250R Tech Talk | 19 | May 1st, 2012 10:32 AM |
Rich or Lean? | ahskeetz | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 7th, 2009 01:22 AM |
