May 8th, 2013, 06:44 PM | #1 |
Join Date: Sep 2011 Motorcycle(s): 2011 Ninja 250r Posts: 17
Post airbox removal questions
Hello,
So i've removed the stock airbox and put on a K&N pod filter and jetted my carb with a Factory Pro jet kit with the help of the DIYs that i came across on this forum. As I was putting the bike back together i came across a tubes that i cant find where it belongs to; the tube is connected inbetween the 2 carburetors. I also found a tubes that is connected to, what i think is, the "vacuum switch valve" and WAS connected to the stock airbox. I'm not sure what i'm suppose to do with this tube after i remove the stock airbox... Thanks a lot. |
May 8th, 2013, 06:56 PM | #2 |
dirty boy
MOTM - Apr '14
check out the remove Kleen air system DIY. you will need either a block off plate or some vacuum caps for the stock plate + cap for the one T junction
as far as that one hose, if you did not disconnect anything you should not have it has to go to the gas tank somewhere as i think those are the only hoses you have to disconnect other than Kleen air system stuff which you did not remove |
May 8th, 2013, 07:08 PM | #3 |
omg. i wasn't able to find anything searching before you told me to search for "kleen air" sorryyyyyyyyyyyy
May 8th, 2013, 07:10 PM | #4 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
or you can put a filter on the big hose and shoot fire out the tail pipe.
the hose from the carb is a drain tube that should go down thru a loop in the frame |
May 11th, 2013, 01:28 AM | #5 |
If i do go on to remove the kleen air assembly, would i have to re-jet? On the DIY thread they said no but then (I think) some people hinted that it might be necessary ... Because it causes it to run richer? Our something like that? I mean, i already bought that block off plate and will most likely go through with it but just want to know what to expect
May 11th, 2013, 04:54 AM | #6 | |
May 11th, 2013, 02:28 PM | #7 |
Thanks. I actually just got the plate in the mail just now but its raining so i can't put it in by the way, is there a gasket that i should replace when switching to the block off plate? I couldn't find it on the parts store.
May 11th, 2013, 06:50 PM | #8 |
Board Member
No gasket needed but you can seal it up with a good rtv or other.
***if I remember correctly*** |
May 12th, 2013, 04:14 AM | #9 | |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
Also, you might want a 5/8th clamp-on breather for the lower part of that Kleen air delete. I believe it's in the DYI, but thought I'd mention it just in case. I purchased this for mine (was $2 free shipping when I got it haha): http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
May 13th, 2013, 01:16 PM | #10 | |
Hey thanks, so i guess ill just forget about the gasket since it isn't necessary and about
May 13th, 2013, 09:34 PM | #11 |
dont need a breather for kleen air delete with air box removal
May 15th, 2013, 01:42 AM | #12 |
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250r, 2003 GSX R600 Posts: 64
I'm putting my air box back on because of the class I'm racing in and I don't have a hose on that fitting between the carbs. I'm not sure what happened to it but can I cap it off or should I find a replacement hose? You said it's a drain hose? I know about the drain hose that comes from the fuel tank.
May 15th, 2013, 01:48 AM | #13 |
B-Town Ninja
May 15th, 2013, 04:24 AM | #14 |
yeah, you need a breather for the crank case, but not for keen air system delete. that hose is Carb overflow hose, should go down along gas tank drain hose
May 15th, 2013, 04:43 AM | #15 |
May 18th, 2013, 07:32 PM | #16 |
Thanks all! Got everything figured out
May 23rd, 2013, 06:33 AM | #17 |
Join Date: Aug 2010 Motorcycle(s): 2010 Ninja 250R Posts: 54
Just curious...how does the bike run without the airbox, new filter, and jet kit?
airbox realignment problems after carb removal | Akane | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 15th, 2014 01:04 PM |
Snorkel removal questions | NHrider19 | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 6th, 2012 09:05 AM |
Airbox removal and jetting + other questions | kamikaze | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 18th, 2012 08:04 PM |
Airbox removal + Kleen air removal? | MikeBudd | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 16th, 2012 04:57 PM |
Quick Airbox removal question | forevertwowheels | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 14th, 2011 04:31 PM |
