September 1st, 2011, 09:21 AM | #1 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 771
Engine issue
So on my way to work today the bike started acting up. While accelerating the engine was kinda boggy then when I was up to highway speed it wouldn't accelerated past 80mph (indicated 80mph) or rev past 9000k RPMs. Anyone ever had that issue?
September 1st, 2011, 12:53 PM | #2 |
Could be a couple things. One of the more common ones (and easiest to diagnose) is a venting issue with the fuel tank, not letting enough fuel flow at high load / high RPM's. Some related links below:
http://www.ninjette.org/forums/showthread.php?t=75160 http://www.ninjette.org/forums/showthread.php?t=53230 http://www.ninjette.org/forums/showthread.php?t=49466 http://www.ninjette.org/forums/showthread.php?t=49009 http://www.ninjette.org/forums/showthread.php?t=21438
September 1st, 2011, 03:37 PM | #3 |
Here's some more information that might help with a preliminary diagnostics.
This morning I rode my bike to the gym and worked out; then I rode the bike home without any issues. Then I got ready for work (took about 20 minutes) and then I went to work. Once on the highway, I noticed the bike was acting as if it was running out of gas (sputtering when accelerating) and then I realized that I was pretty low on gas so I decided to stop and put a quick splash of gas in. I only put about a gallon since I was running late and I only had a couple of bucks on me. Then I got going and the same thing happened. Once I was at cruising speed (80mph indicated) I realized the issue of not being able to accelerated past 9K RPMs in 6th gear. Once at work, I called a local dealer and they told me it was probably time for my bike to have the plugs changed since I was at 8500 miles and still had the original plugs. They quoted me $150+ parts for this service. Then after work, I rode the bike to a different dealer (after putting about half a tank's worth of fuel in the bike) where they told me it was probably an issue with the carbs, and that I should try Yamaha Ring Free, which is supposed to help clean things out. So I put the stuff in and filled the tank up all the way and rode the bike home. The problems never ceased. So what do you think is the most likely issue with my bike? |
September 1st, 2011, 03:44 PM | #4 |
Do you know how how to remove the tank? Changing the plugs is fairly easy and will only cost less than $10 for the plugs if you do it yourself. That way you can cross that off the list. Valve check is also supposed to be at 7500 miles but not as easy (and very time consuming).
Haven't heard of Yamaha Ring free, but another simple solution to clean the carbs (not as well as actually physically cleaning it) is Seafoam. |
September 7th, 2011, 11:19 AM | #5 |
So I talked to a guy my dad works with and he gave me a suggestion. He suggested I look for some sort of a screw(?) that is located on the bottom of the carb connected to a vent tube(?) that will allow me to drain some fuel and (hopefully/maybe) a piece of dirt or debris that could be trapped in there. My question is, where is this tube on out bikes? Pictures or other threads would be grand.
September 14th, 2011, 02:36 PM | #6 |
Well today I drained the carbs via the float bowls. I did both carbs one then went for a quick ride, which left the bike feeling pretty good except for a little hiccup in first gear when going WOT. Then I parked it and drained the carbs again, and went for another ride. The engine was the exact same, if not a little worse. This obviously pissed me off. For the record, I did get a very small amount of dirt when I emptied both carbs.
Would these results lead you guys to believe that I need to just remove the carbs and give them a thorough cleaning? |
Engine Issue... Sounds "Throaty" | swede core | 1986 - 2007 Ninja 250R Tech Talk | 16 | April 25th, 2013 08:32 AM |
[topix.net] - Hitler's personal plane was powered by this US-designed engine [Engine | Ninjette Newsbot | Motorcycling News | 0 | June 14th, 2011 03:10 PM |
[kropotkin thinks...] - Engine List From Sepang 2010 - Engine Penalties Loom | Ninjette Newsbot | Motorcycling News | 0 | October 13th, 2010 04:00 PM |
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2010 07:50 AM |
Have a lean issue with my bike, issue with coasting enricher. | twiggy2cents | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 24th, 2010 06:54 PM |
