January 14th, 2014, 08:36 PM | #1 |
Join Date: Jan 2014 Motorcycle(s): Current Bike: 2004 Kawasaki Ninja 250R Posts: 8
2004 Ninja 250R Streetfighter which parts?
Hey everyone. Im new and im not sure where to put this sorry, I was wanting to jump into making streefighter bikes So i bought an 04 Ninja 250R..for $750...the front nose fairing was gone and id like to put aftermarket headlight/nose on. Id love to get the Z1000 look...does anyone have any ideas?
Also, could i fit the 08 ZZR 600 tail onto the 250 if I modify the underseat frame? thanks.
Current Bike: 2004 Kawasaki Ninja 250R Past Bikes: 2005 Kawasaki Z1000,2008 Kawasaki Ninja 500R |
January 14th, 2014, 09:18 PM | #2 |
This might help:
http://www.ninjette.org/forums/showthread.php?t=28216 |
January 14th, 2014, 09:39 PM | #3 |
Thanks! Id love to do that to it, but mine is a difrent body style, that was a newer 08+ style(which i love!)
January 15th, 2014, 06:12 AM | #4 |
Join Date: Apr 2013 Motorcycle(s): '86 Honda VFR700 Posts: 173
Take a look here to start with. Personally, I'm planning to streetfighter my ninjette when I can afford it. I'd be removing all the fairings but the side panels, rear, and lower, and trading out the stock headlight and turn signals for something like this and the stock mirrors for something like this. Keeping the stock tach/etc to save money. I'm also going to do this fender 'removal'.
Closest picture I can find online to what this will look like is this: But with all the colors matching, and red, in my case. Hopefully that helps! |
January 15th, 2014, 04:26 PM | #5 |
Awesome! thats the healight/nose id like, ill keep the fairing underneath, but take off the sides and somehow switch the tail section to something like this...
still tossing around ideas
January 16th, 2014, 01:48 PM | #6 |
Ok, so ran into an issue tday. I started it up and ran some sea foam in it and it took was having troubling idling. I rode it with th choke at about half to keep it runnin and eventually down the road, was fine with no choke, then i stopped and it died...wouldnt start back up so i had to push it back to the house.
Any ideas as to what thats causing this? I was thinking carbs or fuel filter...
January 16th, 2014, 01:56 PM | #7 |
Ms. Personality
How much Seafoam did you use? Alot of it will prevent an engine from running. If you used a lot of it dump the tank and refill with fresh gas.
January 16th, 2014, 02:13 PM | #8 |
hmmm i think about 6 ounces.
EDIT: I got it runnin...let it sit for 15mns, and playd with the petcock, also had to make sure it was on reserve since it was low on gas. Another thing tho,when i twist the throttle and give it gas, it will die if i only give it like 1/8 turn..if i give it alot of throttle it ok.idk if that would be the throttle cable or carbs acting up...
January 16th, 2014, 05:26 PM | #9 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
I've run seafoam before and I think it's a waste of money personally.
Your issue could be many things. Check all of your cable slacks and adjust your idle next time your engine is warmed up.
Mods: Offset clutch pressure plate |
January 16th, 2014, 07:06 PM | #10 | |
If it still does the same thing, chances are the pilot jets are plugged - which means the carbs need to be removed and properly cleaned. What you described is typical of plugged pilot jets, but confirm you have good fuel before taking things apart. It's always a good idea to keep the tank as full as possible to avoid condensation. Ethanol-free gas will usually make a stock engine run better (if it's not been adjusted for gas with ethanol). Gas with ethanol will make a carbed engine run lean. |
January 16th, 2014, 07:57 PM | #11 | |
Thanx.
January 16th, 2014, 08:33 PM | #12 | |
You also need a way to sync the carbs. The carbs must be synced in order to run properly. |
January 16th, 2014, 08:36 PM | #13 | |
On a sidenote, i started easy..took side fairing off and painted gloss black..ill take off the fender, gas tank, and tail and paint them aftr i get this idling/throttle prob sorted out I also bought a 2002 zx6 tail fairing for 23$ off ebay! Has some cracks but im gonna bondo them Then retro/fab it onto my 250 (hope itll look okay) Cant wait! Pics coming soon. a cheapo acerbis may be all i can afford headlightwise until i save a lil more for a nicer one. Going with black/red highlight schem on the bike
January 30th, 2014, 03:12 PM | #14 |
Im back. sorry for the wait...i took the carbs apart and cleaned em good and now shes runnin almost like new. heres some updated pics.
I made some brackets for the zzr600 tail, and cut and custom formed the stock seat. Still have some more work and wiring to do to it though. I bought the zzr600 taillights and an Acerbis Vision headlight
January 30th, 2014, 10:07 PM | #15 | |
MSF Coach!
Join Date: Jun 2012 Motorcycle(s): 2003 ninja 250 Posts: 886
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35 |
2004 parts | papawhellie | Items Wanted | 8 | October 21st, 2012 12:55 PM |
2004 Ninja 250 parts/whole - TN | ecannon1 | Motorcycle-related | 26 | August 10th, 2010 12:08 PM |
