April 17th, 2014, 11:53 AM | #41 |
EX500 full of EX250 parts
The EX500 is known for having problems if you just slap new pads on without doing a full caliper service. As the pads wear, the pistons stick out further and further past the seals, so you end up with crud on the pistons. If you just push them back in when put on the new (thicker) pads, you end up with issues. Instead, you need to remove and clean the pistons so they mate nicely with the seals. http://www.ex-500.com/wiki/index.php...aliper_Service is a detailed guide to a complete brake service on the 500 (though the 250 should be quite similar).
April 17th, 2014, 07:41 PM | #42 | |
Join Date: Oct 2013 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 219
Prior to purchasing the bike, the previous owner put new pads on for me the day before I purchased it, and I highly doubt that he did a full caliper service. He did not take too much care of the bike. I will take a look at the wiki and see what I feel comfortable doing. Perhaps this is something I should have my local shop do for me... |
April 18th, 2014, 06:08 PM | #43 |
Join Date: Aug 2013 Motorcycle(s): 2012 Ninja 250 Posts: 450
This past winter i had put on new brake pads from magnum and ran into all kinds of problems with them leading up to having to replace both rotors on the bike, they both kept applying pressure to the pads and not releasing with the brake levers. Once i changed to a set of sumo pads from ebay along with new rotors i have not had a single problem since.
As a precaution i would change the pads and make certain that the retaining holes are large enough to not cause it to bind on the pins after release of the brake lever. |
April 19th, 2014, 04:31 PM | #44 | |
Odd fuel observation | slickt0mmy | 1986 - 2007 Ninja 250R Tech Talk | 3 | June 6th, 2013 03:28 PM |
[cyclenews.com] - Nicky Hayden Hoping For Morning Fix | Ninjette Newsbot | Motorcycling News | 0 | April 21st, 2013 05:10 PM |
Weird Fix it Ticket problem. California | Gurk | General Motorcycling Discussion | 13 | March 22nd, 2012 04:53 AM |
A Sunny Observation... | BlueTyke | Off-Topic | 22 | March 28th, 2009 04:06 PM |
question and one observation about ninja 250 | bikermunda | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 9th, 2009 05:19 PM |
