April 22nd, 2013, 02:11 PM | #41 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250R '07 Posts: 81
April 22nd, 2013, 02:15 PM | #42 |
the chain can fly into the air... getting hit by it will do real damage. it can lock up your engine or rear wheel causing you to crash. certain situations can even send the chain up into your leg
April 22nd, 2013, 02:32 PM | #43 |
MOTM - Sep '18, Feb '16
That is normal. I checked my 2008 enigne.
To race land speed I have to have a metal chain guard 1/8 inch thick,
April 22nd, 2013, 03:12 PM | #44 |
Yikes. A sudden rear wheel lock up sounds like a for-sure way to go down very, very hard (being chain-whipped in the face aside).
April 22nd, 2013, 07:16 PM | #45 |
Aimless
Join Date: Feb 2013 Motorcycle(s): 01 ninja 250 Posts: 69
I had a chain break on a trip once. About an hour from home cruising at 70 on the highway. Heard a loud clunk, and then the bike was screaming in the high rpms. Let off the throttle and pulled over, and sure enough the chain was gone. Took a good chunk of engine case with it. Took a nap off the side of the highway while waiting for my wife to pick me up. was my face when it happened.
I just dropped in to see what condition my condition was in |
April 23rd, 2013, 07:36 AM | #46 | |
http://www.newgrounds.com/bbs/topic/1259956 I went down quick and hard when mine locked the rear tire while on a curve. The most impressive thing was how instantaneously the whole thing seemed to happen and my face while I was picking up the bike. You don't know what happened until you try to push the machine out of the way, in a lot of pain and covered by some blood. Luckily, somebody helped me lift the rear and push it. The next ordeal was to un-jam the chain and sprocket from the crankcase (a huge screwdriver and a hammer did it).
April 23rd, 2013, 06:12 PM | #47 |
Board Member
April 25th, 2013, 07:48 PM | #48 |
Join Date: Nov 2011 Motorcycle(s): 2012 ninja 250 Posts: 296
Was bored so i took some YouTube vids it doesn't look like my shaft is bent
http://youtu.be/6CrJ6rfkCkI In this next video I noticed while in natural my front sprocket turns. Is that norm? http://youtu.be/LBn1OF5mUa0 |
April 25th, 2013, 08:31 PM | #49 | |
Join Date: Apr 2012 Motorcycle(s): 1976 CB550 Cafe, 2011 Ninja 250, 1999 Honda CR125 Posts: 264
As far as the shaft goes, looking at it isn't exactly the most scientific approach. The only way to know for sure would be to check the runout, but if you didn't feel any movement at all when you stopped the sprocket with your finger, I would think it would be okay as long as everything is working fine internally. |
April 26th, 2013, 11:15 AM | #50 | |
New parts in the mail, 160 bucks down the drain |
May 3rd, 2013, 10:31 AM | #51 |
Question for you pros
I ordered the wrong part and I did not get that 20mm nut for my front sprocket. I'm itching to ride and got everything else I need, will any 20mm nut work? From like a hardware store? Or is that one special (92015 front sprocket nut) |
May 3rd, 2013, 10:36 AM | #52 |
Nope, you won't find anything like that at any hardware store or autoparts store; ............keep waiting.
May 3rd, 2013, 01:21 PM | #53 |
Dang that sucks. 5 to 7 more days.
May 3rd, 2013, 02:25 PM | #54 |
Join Date: Jun 2012 Motorcycle(s): 1998 Ninja 250 2007 Yamaha R6 2003 Honda RC51... sold :( Posts: 205
Maybe I missed it, but did you ever see if it actually was the master link that let loose?
I honestly don't think it had anything to do with your chain. Like stated above, DID is a good brand. One of the few I'll buy. I think the nut on the front sprocket came off. Did you tighten it with a torque wrench? As to the whole clip on master link argument: If I have a choice, I'll go with rivet style 100% of the time. If there is no choice, I will use safetywire 100% of the time. Lots of people ride without gear or helmets everyday and have zero issues. Doesn't mean I am going to. I also use safety wire on the front sprocket bolt/nut of every bike I own. |
May 6th, 2013, 02:40 PM | #55 | |
I believe my front sprocket nut came off, and thats what caused the problem. I say that because I could not find the washer or the nut anywhere. I don't think it would have unscrewed loose with the chain snapping... This sucks, it's such nice weather! I just want my part to ship! lol. No Kawasaki dealer within 70 miles of me has this part in stock either. No one else has a nut laying around that would work huh? |
Morning Ride to work | checho323 | General Motorcycling Discussion | 4 | April 16th, 2014 10:39 AM |
Interesting ride into work this morning... | gibtzumich318 | General Motorcycling Discussion | 16 | August 29th, 2013 01:29 PM |
Clutch snapped | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 19 | June 21st, 2013 05:03 PM |
[topix.net] - Destination dealer: Free can of SDoc Chain Spray on Ride to Work Day | Ninjette Newsbot | Motorcycling News | 0 | June 15th, 2012 03:30 PM |
*YAWN* Early morning to work | Cali619 | Videos | 22 | August 19th, 2009 07:19 AM |
