Old August 26th, 2011, 01:06 PM   #1
BobsPT
BobsPT's Avatar
Motorcycle(s): 2001 Kawasaki Ninja 250R
How many miles, on reserve?
I've always had the habit of filling up, at the earliest possible, after turning on the reserve. Just recently, in one of these forums, someone had mentioned something about running on reserve for a few(30-40) miles to clear the tube, or something like that. So, this morning, i decided to do the same, & guess what, the bike stalled after about 15 miles. Luckily for me, a gas station was only a few feet away( what are the chances??) & i just pushed it in. When i opened the tank, i noticed there was still some gas left in it. I always thought the tank would completely empty itself on reserve.
So, what's a safe distance to go on reserve?
BobsPT is offline   Reply With Quote
Old August 26th, 2011, 01:13 PM   #2
Snake
Snake's Avatar
Same as you I always look for the nearest gas station so I have never tested how far I can go on reserve.
Old August 26th, 2011, 01:44 PM   #3
A7xschecter6661
A7xschecter6661's Avatar
Motorcycle(s): 2003 Yamaha R6
Well I usually get about 200-220 miles on 3.5 gallons.
That being said there is according to the specs of the bike, 1.3 gallons left.
So If I get 60-65mpg I could go that far, but usually i just fill up as soon as it goes to reserve or anytime after 200 miles.
I don't like pushing my luck
A7xschecter6661 is offline   Reply With Quote
Old August 26th, 2011, 02:16 PM   #4
BobsPT
BobsPT's Avatar
Mine goes on reserve a little after 200 too. well, the experiment proved that i'm better off doing what i had been. Anyways, all's well & i'm glad i didn't try this on the freeway.
Thanks Guys.
Old August 26th, 2011, 02:41 PM   #5
bluepoof
bluepoof's Avatar
Motorcycle(s): 2007 Ninja 250, 2002 Yamaha XT225
I had the opportunity to try this out just last night! I sputtered to a stop on the shoulder of the freeway at 10pm last night with just 185 miles on the odo. The closest gas station was about 15 miles away and when I got there, I put 4.35 gallons into the tank.
www.bluepoof.com
bluepoof is offline   Reply With Quote
Old August 26th, 2011, 02:51 PM   #6
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
I got about 10 miles from mine when I hit the reserve (my old 04)... not even sure w my new gen as it has no reserve anymore.
Old August 26th, 2011, 04:18 PM   #7
BobsPT
BobsPT's Avatar
Sorry about your bad luck, Carolyn. Glad it has worked out but how did you manage to get to the gas station? So, is it normal to have such big variations in mileage?
Old August 26th, 2011, 05:06 PM   #8
bluepoof
bluepoof's Avatar
Oh, I flipped to reserve on the side of the freeway (where I also learned that the flashlight I keep in my tankbag had dead batteries. ) The 15 miles to the gas station was on reserve.
www.bluepoof.com
Old August 26th, 2011, 07:04 PM   #9
A7xschecter6661
Always remember so you can do it while riding when it starts to sputter.
Where do you want to continue going?
Forward!
Flip it forward
Old August 28th, 2011, 05:09 PM   #10
n4mwd
n4mwd's Avatar
What was meant was that every month or two you should flip to reserve after a fill up and rid it home that way just to prevent gunk from building up in the bottom of your tank near the reserve strainer inlet. Then flip back once you get home. If you forget to flip back, you may run out of gas with no reserve.
If you run out of reserve, there is usually still a little gas in the right side of the tank that you can slosh over and get a few more miles.
Last I heard, flipping to reserve gives you another 20-30 miles. I usually just make a habit of filling up at 200 miles.
My Ninja Blog
Old August 29th, 2011, 06:34 PM   #11
BobsPT
BobsPT's Avatar
Thanks for clarifying D. That was exactly the post i was referring to. I must have misunderstood it. Now, it makes more sense.
Old August 30th, 2011, 08:11 PM   #12
kimboEX250
kimboEX250's Avatar
Motorcycle(s): 2002 Ninja EX250
i rode almost 30 miles on reserve today before i decided i shouldn't push my luck. it is a good idea to use the reserve often to prevent bad fuel and/or clogging of the reserve line. if this is the first time the bike has been riddin on reserve that may be why you were limited to only 15 miles? drain the tank, remove the petcock and clean/inspect the screen filters on both the "on" line and "reserve", fill her up with fresh fuel,
kimboEX250 is offline   Reply With Quote
287 miles to reserve... gitoy General Motorcycling Discussion 3 July 19th, 2010 08:15 PM
