July 16th, 2017, 04:51 PM | #1 |
Join Date: Jul 2017 Motorcycle(s): 2003 Ninja 250R Posts: 32
Carb Cleaning Annoyance
Was working on the carbs today and both mixture screws' washer and o-ring are stuck. I was tempted to use an eyeglass screwdriver to fish them out but thought the better of it when I realized the side walls may get damaged.
Any suggestions? |
July 16th, 2017, 05:17 PM | #2 |
I can't imagine you'd cause any problem if you carefully fished them out with a jeweler's screwdriver or a tiny hook of come sort.
July 20th, 2017, 12:02 PM | #3 |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 460
I have had good luck with a pipe cleaner. just push it in and pull it out until the o-ring, and / or washer "stick" to it. It takes a few tries...
... can't stop updating the bike! |
4k Idle after carb cleaning | chibit89 | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 8th, 2016 08:49 AM |
carb removal/cleaning | yenome | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 27th, 2016 09:44 PM |
Carb cleaning QUESTION | ortizj2289 | 2008 - 2012 Ninja 250R Tech Talk | 17 | April 3rd, 2015 01:19 PM |
First Carb Cleaning | Achilles | 2008 - 2012 Ninja 250R Tech Talk | 33 | February 1st, 2013 11:48 PM |
Carb Cleaning?? | jboyd12 | General Motorcycling Discussion | 11 | March 3rd, 2012 10:05 AM |
