August 27th, 2015, 12:20 PM | #1 |
[motorcyclistonline] - 2016 Harley-Davidson FLSS Softail Slim S | FIRST RIDE
Some combinations don’t sound right but are. Like olive oil and ice cream. (Try it.) But some combos just seem destined to work. Like Harley cruisers and (more) displacement.
Which is exactly what’s behind the Harley-Davidson S models just brought into the Softail lineup for 2016. Both the Fat Boy S and the Softail Slim S kick the traditional 103ci air-cooled lump to the curb and grab the gutsy 110-inch engine previously only available in the much more expensive CVO models or via the aftermarket. This twin-cam, air-cooled beast puts down 109 pound-feet of torque at 3,500 rpm, a gain of almost 8 pound-feet over the 103ci engine, which is a little shy of what this displacement does in the actual CVO models. But that’s just what the specs sheet says. In person, the big engine proves to have a nearly bottomless well of torque that is impressive in the (relatively) light Softail chassis. Grunt everywhere, terrific throttle response, and it’s even pretty smooth thanks to twin counterbalancers, which have been part of the TC-B engine series since 2000. Other updates for the Slim S include a hydraulic clutch and Stage 1 high-flow air cleaner. In the case of the Softail Slim S, the blacked-out engine is joined by really cool military-style paint scheme that Harley is quick to point out is not a replica of anything. The semi-matte, olive-not-quite-drab scheme called Olive Gold Denim has gold flakes under the surface and looks stunning in open sunshine. Against the blacked-out scheme, the Slim presents a purposeful appearance. Just retro enough. Dynamically, the Slim S is your basic modern Softail, with low-slung, half-moon-shaped footboards waiting to kiss the ground and a single front disc that’s just good enough, backed by effective ABS. For 2016, cruise control becomes either standard or an option across the Softail line; it’s standard on the Slim S along with a security system and ABS. Thing is, the Softail is such a relaxed machine, so at home hammering through an urban landscape. It sounds trite but it’s true: The Softail’s sense of balance, low seat, and predictable steering make it a low-effort ride. And then there’s the new power, which delights every time the light turns green. TECH PRICE $18,899ENGINE 1801cc, air-cooled 45° V-twinTRANSMISSION/FINAL DRIVE 6-speed/beltCLAIMED HORSEPOWER n/aCLAIMED TORQUE 109 lb.-ft. @ 3500 rpmFRAME Tubular-steel double-cradleFRONT SUSPENSION H-D 49mm forkREAR SUSPENSION H-D shocks adjustable for spring preloadFRONT BRAKE Hayes four-piston caliper, 300mm discREAR BRAKE Hayes two-piston caliper, 292mm discRAKE/TRAIL 32.1º/5.8 in.WHEELBASE 64.4 in.SEAT HEIGHT 28.2 in.FUEL CAPACITY 5.0 gal.CLAIMED WEIGHT 712 lb. wetAVAILABLE NowCONTACT harley-davidson.com Click here for full story...
[motorcycle.com] - 2016 Harley-Davidson Softail Slim S – First Ride Review | Ninjette Newsbot | Motorcycling News | 0 | August 25th, 2015 07:40 PM |
[motorcyclistonline] - 2016 Harley-Davidson Softail Slim S & Fat Boy S Get Screamin’ | Ninjette Newsbot | Motorcycling News | 0 | August 23rd, 2015 07:30 PM |
[motorcycle.com] - Twin Cam 110 Harley-Davidson Fat Boy S and Softail Slim S for 2016 | Ninjette Newsbot | Motorcycling News | 0 | August 12th, 2015 09:30 AM |
[motorcyclistonline] - Harley-Davidson Softail Slim | First Ride | Ninjette Newsbot | Motorcycling News | 0 | June 6th, 2012 03:00 PM |
[topix.net] - 2012 Harley Davidson Softail Slim | Ninjette Newsbot | Motorcycling News | 0 | February 8th, 2012 07:30 PM |
