November 7th, 2010, 01:39 AM | #1 |
Join Date: Jun 2010 Motorcycle(s): 2010 Ninja 250 Posts: 133
It won't start.. left outside in 40+ degrees for just half a day. Need help..
So I left my bike in the morning and then when I tried to start it last night it wouldn't. I wait for about 5 mins and try to start it again...it does sometimes but after like 3 seconds it dies..even with the choke on..did something freeze up? like the fuel lines? it was 40+ degrees outside and its the first time this happened...
the bike usually is in the garage in the morning before I start it so Its the first time it stayed outside for this long with the current weather...now I'm stuck and sleeping over at my friend's house..good thing she's hot..lol j/k ...please help! |
November 7th, 2010, 01:58 AM | #2 | |
November 7th, 2010, 07:00 AM | #3 |
Yup! No throttle .
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
November 7th, 2010, 11:47 AM | #4 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
give your idle knob a half-turn in... Once the bike is warmed up, re-set your idle....
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
November 7th, 2010, 01:57 PM | #5 |
It worked with no throttle and just the choke at full..wow that was easy... thanks a lot guys! now question is how come you don't need to use the throttle? sometimes people use it to start the bike..
November 7th, 2010, 02:05 PM | #6 |
I generally pull the choke to full and then as I start cranking I slowly move the choke back toward open until the engine starts, usually within a second or so. The choke provides bypass air so the throttle doesn't need to be open, and in fact opening the throttle just dilutes the extra fuel the choke is putting into the intake air stream. It takes practice, they're fairly cantankerous since they don't have EFI.
Won't start | Espinoza07 | 1986 - 2007 Ninja 250R Tech Talk | 6 | September 14th, 2014 08:07 PM |
[motogp.com] - Tech3 duo eager to kick start second half of season | Ninjette Newsbot | Motorcycling News | 0 | August 7th, 2014 03:42 AM |
Bought first bike and 1 day later it won't start: do I have a junk bike? | brendandubs | 1986 - 2007 Ninja 250R Tech Talk | 43 | May 11th, 2014 07:59 AM |
Won't start... :( HELP! | deeno415 | 1986 - 2007 Ninja 250R Tech Talk | 59 | August 31st, 2013 05:53 PM |
Won't start | Momaru | 2008 - 2012 Ninja 250R Tech Talk | 15 | August 9th, 2009 09:48 PM |
