May 2nd, 2015, 05:23 PM | #6601 |
Installed new Motion Pro clutch cable, and replaced the ignition wires.
Full write-up/blog about ignition wire, and plug cap maintenance coming soon
May 2nd, 2015, 06:17 PM | #6602 |
Join Date: Mar 2014 Motorcycle(s): Currently own: 98 Honda VTR1000, 02 Suzuki's DR200 & DR650, 04 & 08 BUSA's, 05 Ducati SS1000, 12 Ninja 250R SE Posts: 59
Replaced the opening throttle cable on my 2012 Ninja 250 SE. The plastic fitting at the handlebar end was broken. I think it was like that when I took delivery last year.
Anyhow, it cost me $28 and 1 hour of my time. |
May 2nd, 2015, 06:20 PM | #6603 |
Certified looney toon
MOTM Jul '13, Jul '14
Turned her over to the shop for a way overdue valve adjustment, and some basic checks on various service stuff.
May 6th, 2015, 09:52 AM | #6604 |
MOTM - Sep '14
245 miles from curent tank of gas.
I think I could get 10 or 15 miles more. I'm not going to test that.
May 6th, 2015, 09:58 AM | #6605 |
Fighting Texas Aggie '05
Picked up set of F/R wheels with rotors/cush/etc for MKlein3004's race bike for $200. Figured that was a pretty good deal.
Took my street ninjette out for ride this weekend to test the S20 Evos and came away with a very positive first impression.
May 6th, 2015, 02:02 PM | #6606 |
Fogwalker
Join Date: Mar 2015 Motorcycle(s): '09 Ninja 250 "Matilda" Posts: 124
'Flame' got a new set of tires. (Yes, those are jack-stands and a Toyota jack.) She's almost street ready.
Ride on, J~
Take care of new riders, for we were them, and they will be us. Y. Hong 2004 |
May 6th, 2015, 02:12 PM | #6607 |
Nothing beats a new pair of sneakers.
May 6th, 2015, 03:07 PM | #6608 |
sammich maker
MOTM - Apr '15
Added 100 miles to the odometer.
May 7th, 2015, 06:47 AM | #6609 |
Join Date: Apr 2014 Motorcycle(s): 1980 Yamaha XS850G Midnight Special, 32k Miles; 2000 EX250F, <5000 Orig Miles Posts: 98
Installed JT Sprockets 15T front sprocket. Installed newgen rear shock. Oil and filter change with screen cleaning. Brake fluid change, Front and Rear.
May 8th, 2015, 12:50 PM | #6610 |
Join Date: May 2015 Motorcycle(s): 2005 Kawasaki Ninja ex250 Posts: 11
Slammed it.
May 8th, 2015, 03:11 PM | #6611 |
That 1 Guy
Join Date: Apr 2015 Motorcycle(s): 05' Ninja EX250 Posts: 20
Pulled the carbs out for the 3rd time and installed three #4 washers into both needle jetts
http://www.twitch.tv/turism0remix http://osu.ppy.sh/u/800641 |
May 9th, 2015, 05:39 AM | #6612 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
DJK , a member here and a local if you consider same-state local , hooked me up with some beautiful custom bike parts. Looks great man, thanks again
So hopefully this weeked or next I'll have my bike torn down and an improved look.
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
May 9th, 2015, 02:20 PM | #6613 |
^^^ sharp
May 9th, 2015, 07:18 PM | #6614 |
sammich maker
MOTM - Apr '15
Added stomp grip after a thorough clean, then waxed.
May 9th, 2015, 07:21 PM | #6615 |
Just celebrated SERENITY turning 5k miles since I saved her about a year ago.
May 10th, 2015, 02:05 PM | #6616 |
This won't end well. (keep an eye on your undertail area above the rear wheel)
May 12th, 2015, 06:45 PM | #6617 |
Carbon Fiber wrap the top of the gas tank, to blend in with the CF wrap on upper fairing
May 13th, 2015, 08:04 PM | #6618 |
I picked up a Kisan Pathblazer headlight modulator for about half price.
http://kisantech.com/mag/index.php/p...zer/p115w.html Ride report: it definitely draws attention to the bike, a lot of attention which is the main purpose of the modulator. Even a few cagers whom were pulling out, stopped instead, which I found very interesting. I have it hooked to an inexpensive CREE LED H4, so the response time of the light is excellent. The unit it turned on when you switch to the hi beam, during daytime. The unit comes with a daylight sensor, if needed switch to low beam to deactivate the unit. Final verdict: it works.
May 13th, 2015, 10:33 PM | #6619 |
Welp, first major service needed I suppose.
New rear tire New Shift Shaft and Tie Rod New Speed Sensor Valve Adjustment (opps, skipped the last two scheduled adjustments) Also adjusted the brake lever and now the front brakes engage with the slightest pull vs a full on grip.
May 17th, 2015, 01:10 AM | #6620 |
Join Date: Mar 2015 Motorcycle(s): SV650, Pregen 250, Monster S2R Posts: 4
EBC clutch springs
Motion Pro clutch cable Motion Pro clutch lever Motion Pro brake lever Checked valve clearances (all within spec, yay) Oil filter+change Bled brakes Adjusted chain slack Also figured out why it seemed like the sidestand sensor was bypassed... clutch sensor is broken (always open). Aaaand discovered it's time for new fork seals. |
May 17th, 2015, 06:05 AM | #6621 |
Lol dude...
Cars look alright when they're lowered a little (but still keep normal camber!!!) and I can appreciate that because there is some benefit to handing to a point, depending on the vehicle. But unless the rider is tiny, bikes look super stupid when they ride by if they're lowered like that. |
May 18th, 2015, 06:28 AM | #6622 | |
May 18th, 2015, 06:44 AM | #6623 | |
However my speedo is acting up again. Might just switch to Koso's magnetic pick up and bypass the stock mechanical one.
May 18th, 2015, 11:00 AM | #6624 | |
Saw your post on SVRider.com about picking-up the Ninja. Lots of fun to mess around with. We have 2 now, just picked up a project from a member here. Keep us posted on what you are up to with it. |
May 18th, 2015, 03:41 PM | #6625 | |
My role with the bike is mostly in-house mechanic (we picked it up a couple months ago), but it's a ton of fun whenever I get some time with it. Brings back memories of growing up and riding small japanese standard bikes. Last night I gave it a quick bath so it was pretty for today's riding. |
May 18th, 2015, 09:17 PM | #6626 |
*grin*
May 19th, 2015, 03:24 AM | #6627 |
Certified Troublemaker
May 19th, 2015, 07:16 AM | #6628 |
Motorcyclist
Join Date: May 2010 Motorcycle(s): 2014 Ninja 300 ABS Posts: A lot.
I bought the Ninja 300 last year, after having 2-5 bikes at a time for years and years I decided to sell my last other two other bikes... Yamaha FZ09 and Victory Cross Country, and ride the Ninja 300 as my one and only. I am truly impressed how improved this 300 is, for my needs/wants this checks all the boxes.
I should do a thread at some point with my mods/bolt on's, thoughts and opinions. |
May 19th, 2015, 03:04 PM | #6629 |
May 19th, 2015, 03:07 PM | #6630 |
Had a friend replace my rear 45 with the Michelin Pilot Power. The radial is so soft and pliable.
May 19th, 2015, 04:04 PM | #6631 |
Maybe.
I'd really like to have aux lights at some point.
May 19th, 2015, 05:20 PM | #6632 |
How much extra does your charging system have left to spare?
May 19th, 2015, 10:42 PM | #6633 |
Not sure but my voltmeter drops to orange with my jacket and high beam on.
Today: installed the Koso speed sensor to bypass whatever is going on with my speedo. Also tried aligning my headlight and test rode the Corbin.
May 23rd, 2015, 10:34 PM | #6634 |
cadd cadd cadd
MOTM - May '15
Tested out my DIY luggage rack. Best of all, it's free!!! Did three test runs with it. Verdict: Darwin was waiting for me.
May 23rd, 2015, 11:43 PM | #6635 |
Join Date: Nov 2012 Motorcycle(s): '07 ex250-F/J Posts: A lot.
cut the lower fairing..because muzzy!!
Will tune in a couple days!! Can't wait |
May 24th, 2015, 07:01 AM | #6636 |
May 25th, 2015, 06:19 AM | #6637 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Spent two hours cleaning RTV off a gasket surface.
May 26th, 2015, 09:03 AM | #6638 |
cadd cadd cadd
MOTM - May '15
Trying to see how long I can go without washing the bike. Last time I washed it was around Thanksgiving when I was prepping it for storage.
So, 6 months so far. I'll see if I can make it 1 full year
May 26th, 2015, 03:50 PM | #6639 |
Yuck!
May 26th, 2015, 03:53 PM | #6640 |
Join Date: Dec 2013 Motorcycle(s): 2011 250R SE Posts: 326
I want to live where you do. That photo is what I hit in less than a month.
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
