January 9th, 2010, 05:27 PM | #1 |
When to go synthetic
When do you guys recommend I switch to synthetic?
I have about 100 miles right now and I plan on doing the following: 200 - oil change with regular oil 400 - oil change with regular oil 600 - oil change with regular oil 1000 - oil change with synthetic Does that sound good? Or should I go part-synthetic on 1k miles? |
January 9th, 2010, 05:30 PM | #2 |
You can safely switch to synthetic oil after the break-in is over.
January 9th, 2010, 05:35 PM | #3 |
Join Date: Mar 2009 Motorcycle(s): '09 Ninja 250 Black Posts: A lot.
U don't need to have that many oil changes before 1,000 miles.
I'm not small, I'm fun sized |
January 9th, 2010, 05:56 PM | #4 |
Join Date: Sep 2009 Motorcycle(s): 09 Ninja 250R SE Posts: 376
January 9th, 2010, 06:00 PM | #5 |
By the way, do you plan on replacing the crush washers each time? If you're changing the oil that many times with the same washer, that could be bad. I'd change it each time to be safe. I got my crush washers straight from the dealer.
Ride safe and have fun! |
January 9th, 2010, 06:38 PM | #6 |
Samer, What did Kawi charge for the washers? I have 8500 mi on my Ninja, run Rotella-T Synthetic, and have not changed crush washers. I use a torque wrench on the drain plug and filter plate. My oil changes are every 3000 mi. The drain plug has not leaked any oil to date. I changed to Synthetic after 1000 mi. and have had no problems---in fact my shifter operates a lot more smoothly with synthetic. As Blue Raven said, you don`t need to change oil that often. I changed with regular Kawasaki 10-40 at 100 mi and then changed to Synthetic at 1000 mi. After that, I change oil and filter every 3000 mi.
January 9th, 2010, 06:46 PM | #7 |
January 9th, 2010, 06:47 PM | #8 |
Yes, I plan on replacing the washers and o-rings each time. I'm still getting the hang of this. I was super, super close to dropping the bike today
January 9th, 2010, 08:07 PM | #9 |
You can run synthetic at 1 mile... all the talk about it being bad is hogwash. However! Using synthetic during your multi-oil-change break in period is kinda expensive.
January 9th, 2010, 08:35 PM | #10 |
I have 18,000 and have never changed out my crush washer with no leaks so far. Although I think during my next oil change it would be a good idea to change it. Cheap insurance.
January 10th, 2010, 04:11 PM | #11 |
Interesting feedback. I can't remember how much the crush washer cost, maybe 75 cents each or a dollar. For those who never changed it and didn't have any problems, Does it always stay stuck on the drain plug the whole time? If so, I can imagine that it tightens in the same location each time so it is okay, if it rotates relative to the bolt, that could be an issue I imagine. That thing is very soft. I know because I had a lot of trouble taking it off the bolt. That was my first ever oil change so I'm still learning.
For sure, use a torque wrench every time regardless! |
January 10th, 2010, 04:21 PM | #12 |
I use K&N oil filters and they come with the o-rings so i change them everytime. A torque wrench is a must for almost everything u do on this bike.
January 10th, 2010, 04:25 PM | #13 | |
By the way, mine was clearly depressed (circle mark) by the bolt when I took it off. Maybe the dealer torques more than 14.5 ft-lbf. |
January 10th, 2010, 08:10 PM | #14 |
self wrencher
There's a thing called an oil filter that filters out metal shavings
Posted via Mobile Device |
January 10th, 2010, 08:51 PM | #15 |
Join Date: Dec 2009 Motorcycle(s): 2 2009 Ninja 250's Honda VTX 1800 Posts: 40
I changed my oil at 50 miles and went with Mobil 1 full syn. Syn oil is fine from the start. I have done this with all my bikes and never a problem.
January 10th, 2010, 09:26 PM | #16 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
And your basis for this bold statement rock is ????
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
January 11th, 2010, 01:35 AM | #17 |
then how do you account for the metal shavings on the bottom of the oil pan when doing an oil change? I agree with you that any oil with shavings that does pass through the filter will have the shavings filtered out, but who says all oil in the engine will be cycled through the filter?
January 11th, 2010, 06:20 AM | #18 | |
IC2(SW)
Maybe it's: look at all the cars that come with it from the factory. http://www.mobiloil.com/USA-English/...ics/Myths.aspx |
January 11th, 2010, 08:56 AM | #19 |
Someone who has been testing and developing tests for oils in gasoline and diesel engines and has been doing this for 20-something years, it's what he does for a living. When Mobil wants their Mobil 1 oils tested by an independent lab, he's one of the people who do it. I consider him the upper-most authority when it comes to engine lube
January 11th, 2010, 09:12 AM | #20 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
RockNroll, sorry, but thats not entirely correct.
All that "wait certain miles before switching stuff" started with the Harley Davidson engines. The seals in them would soak up the standard oil. Once they switched to synthetic, the seals wouldnt soak up the synthetic. They started shrinking, and leaking like crazy. Thats why you'll be hard pressed to convince some HD riders to ever use synthetic oil. There's also the issues with clutch plates. In a car, it doesnt matter because the clutch plates arent bathed in engine oil.....but in a motorcycle, they are. During the break-in period its important for the clutch plates to bed in. If they dont you'll have issues. |
January 11th, 2010, 09:16 AM | #21 | |
Actually... it is correct.
January 11th, 2010, 09:52 AM | #22 | |
IC2(SW)
Break in a clutch... ??? Where did you hear this? |
January 11th, 2010, 09:58 AM | #23 |
Here's a little page to read. We are an Amsoil dealer and before we started carrying Amsoil I used Mobil 1. I use Amsoil now because I get it wholesale. The wet clutch is addressed here.
http://www.smartsynthetics.com/artic...ical_facts.htm
January 11th, 2010, 10:09 AM | #24 |
Right, it's my understanding the wet clutch issue isn't as much a synth vs. non-synth concern, it's a matter of whether those additional friction modifiers are put into the oil. Those friction modifiers help improve fuel economy in cars, but can cause clutches to behave funny on bikes.
January 11th, 2010, 10:57 AM | #25 |
Is it correct to say whether you are using conventional or syn oil just make sure it is not fuel conserving oil?
January 11th, 2010, 02:17 PM | #26 |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
Generally speaking, yes. Fuel Conserving oils have large quantities of additives that are the friction modifiers that don't get along well with wet clutches.
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
January 11th, 2010, 02:24 PM | #27 | |
January 11th, 2010, 04:24 PM | #28 |
Thanks Rock, I'll look for the label.
January 14th, 2010, 04:42 PM | #29 |
kinda sorta noob
Join Date: Dec 2009 Motorcycle(s): '03 and '08 Posts: 62
do i have to totally drain the oil to switch?
or can i just drain as best as i can, and then start with synthetic? can i mix the two?
January 14th, 2010, 06:45 PM | #30 |
synthetic helps prevent engine wear, this is exactly what you do not want during break in period
January 14th, 2010, 09:03 PM | #31 |
Join Date: Jan 2010 Motorcycle(s): '09 EX250J, '01 CBR600F4i Posts: 53
i had the 600 mi service done at about 650 or so, no real idea if they used syn or regular. also got it changed around 3000, same deal. i think they stuck with regular unless i requested syn specifically because it would have been more expensive. regardless, no problems with the bike whatsoever.
January 15th, 2010, 04:19 AM | #32 | |
I really lol'ed at that.
January 15th, 2010, 05:56 AM | #33 |
You are sleeping
Not a bad idea to do four oil changes within the first 1000.
I did myself. I think I have changed it six times in 1600 miles. Yesterday at 1600 on the nose. Now that she's mostly broken in, I'll probably wait until 3000mi to change it again. Cost a bunch in oil changes but kept as much of that flake out of my engine as I could while breaking in the bike. Will switch over to Synthetic on my next change. |
January 15th, 2010, 11:40 AM | #34 | |
January 15th, 2010, 01:05 PM | #35 |
IC2(SW)
Switching to Synthetic | sheeb | 2008 - 2012 Ninja 250R Tech Talk | 11 | November 13th, 2013 09:02 AM |
When should I change my synthetic oil? | NinjaBoyEddy | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 21st, 2012 04:43 AM |
synthetic oil vs regular | Shaol1n Monk | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 17th, 2011 09:09 PM |
Synthetic Oil: Bad? | jonthechron | 2008 - 2012 Ninja 250R Farkles | 25 | August 20th, 2010 05:59 PM |
[2fiddy.com] - Switch to Synthetic? | Ninjette Newsbot | Motorcycling News | 0 | October 13th, 2008 08:28 AM |
