June 1st, 2018, 01:50 PM | #1 |
GPS Speedo?
I have my road test coming up in a month and by taking my phone to my tank I found that my speed is 10% lower than the reading, and the dominant scale is mph where I need it to be kph (brain doesn't do the conversion fast enough lol)
Wondering if anyone has tried out one of these GPS-based speedometers they have on Amazon etc? The ones that would drop in where the current one is. Wondering what your thoughts are.. ones like this: https://www.amazon.ca/Waterproof-Spe...fsL&ref=plSrch Or if you've ever replaced one for that matter know what the distance is between mounting bolts on the bottom? Or where to find out.. |
June 1st, 2018, 02:17 PM | #2 |
I know guys with GPS speedometers and they're OK. Accurate most of the time, but have a lag when starting out, and can lose the reading if you're riding down a road with a lot of trees, for example. I've decided that any of the electronic ones that let you calibrate them are better for my use. You put a magnet on a wheel or rear sprocket, and a sensor to pick up the magnet pulses, and you enter the distance traveled per pulse.
Now for boats it's hard to beat the GPS type. |
June 1st, 2018, 03:39 PM | #3 |
Factory speedo is mechanical with gears and cables. There's a finite amount of gear ratios from hub through speedo-drive and engineers end up with selecting an optimistic combination rather than risk people speeding inadvertently.
Yeah, GPS has slight delay when speed and position changes. If you're going at steady-speed on freeway for several minutes, it'll report accurate speed. But if you do lots of braking in stop & go traffic, it won't be accurate. I use one of these digital Trailtech Vapor gauges. You calibrate it by measuring roll-out distance of front-tyre and plug that into unit. Then it does all the calculations based up on time-interval between each wheel-rotation to arrive at speed, very accurate. I fine-tune the setting using stopwatch and mile-markers on freeway as well as with GPS and it's spot-on to 0.1 kph. I also like having 24-hr clock and actual coolant-temp readouts (in F or C). Stores maximum speed and temps for later recall. Programmable RPM shift-light. |
June 1st, 2018, 10:51 PM | #4 | |
All that said, I can't confirm that the GPS chips put into a knock-off gauge cluster will be awesome, OK, or 15 year old tech that might have issues. But my hunch is it would be harder to buy one now that works (but works badly), as even the best GPS chipsets are dirt-cheap in 2018.
June 2nd, 2018, 09:09 AM | #5 |
Hey guys thanks for the responses! I've been looking at options since I posted including the Trailtech Vapor and it looks like that may be the route to go, despite it seeming like a solid day or so realistically required to get that mounted and wired up. The instrument cluster on the 07 looks like it might be one piece and hence not just replaceable with a single-instrument drop-in. I just know from personal experience that anytime a mod is required I need to add at least a day to fiddling and fitting etc
June 2nd, 2018, 11:23 AM | #6 |
MOTM - July '15
Yeah, the cluster on the 07 is indeed one piece. It has a trim piece:
The cluster: And the gauges that come out like this: While I don't think it'd be impossible to replace JUST the speedo, I don't think it'd be worth your while. |
June 2nd, 2018, 07:33 PM | #7 |
I’ve got one of those Speedos from the amazon link on my bike and it works great. Only con is it can take a minute to find satellites to link up to. Not sure about the mounting as I made a bracket for mine and put it right on the triple clamp.
[RoadRUNNER] - Motorcycle Navigation: GPS Block 3—The Future of GPS Navigation | Ninjette Newsbot | Motorcycling News | 0 | August 11th, 2017 04:00 AM |
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd | Klondike1020 | General Motorcycling Discussion | 8 | August 17th, 2014 12:23 AM |
gps'd my 2006 speedo, still uncertain | xorbe | 1986 - 2007 Ninja 250R Tech Talk | 4 | July 14th, 2014 07:42 AM |
My speedo is off??? | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 28th, 2010 03:24 PM |
GPS speed vs speedo | backinthesaddleagain | General Motorcycling Discussion | 15 | August 18th, 2009 08:50 AM |
