March 29th, 2013, 07:35 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 2005 Kawasaki Ninja Posts: 29
Working on a 05, starts and runs, just no throttle
I just got a 05 ninjette from a friend for free. Hasn't ran since 06, cleaned the carbs and got it started but it won't go above idle. I did notice I didn't adjust anything hoping that it wouldn't need to be, but seems like it's running very rich. Any pointers would be appreciated.
March 30th, 2013, 06:30 AM | #2 |
Welcome to the site, Dave !!!
Did you check that the throttle is moving in the carburetors when you twist the bar's grip?
March 30th, 2013, 06:53 AM | #3 |
Yes. It just Boggs down and it actually stays running without revving. Idle is tough but it does start and run. I'm taking the carb back out and I'm going to make sure the diaphragms aren't misplaced. Also, I didn't pull the caps on the pilot screws, so I'll be doing that also.
March 30th, 2013, 07:00 AM | #4 |
What about the air intake?
Blocked? Clean air filter?
March 30th, 2013, 09:17 AM | #5 |
When I got the bike a week ago, the airbox was removed and I haven't reinstalled it yet because it's missing some pieces. When I took the tank off today, the gas was jus pouring out. It was fine when I drained the gas out of it. I'm wondering if the petcock is stuck.
I did notice when I had it running yesterday(without the air box) there was some small spatters of gas spraying from the back of the carbs. Would that most likely mean it was way too rich? |
March 30th, 2013, 09:25 AM | #6 |
If the float valves are not closing properly, you may have excessive level inside the bowls and even an overflow.
Back splash may be also related to intake valves that are way out of adjustment or not sealing properly. I would get a repair manual and do some surgery and deep cleaning of everything.
March 30th, 2013, 10:38 AM | #7 | |
April 1st, 2013, 06:07 PM | #8 |
So what I didn't know was the needle jets were installed on top of the plastic spacers instead of under(I put it back the way I found it). Got it running and now seems like it is running very lean. I'm just curious if the airbox not connected is causing it to rev up on it's own? Came down once and was running great but then went to 4000 o n it's own. Checked the idle adjustment and it was barely on.
April 1st, 2013, 06:21 PM | #9 |
it will be extreeeeeemely lean without the airbox on. also examine the fuel enricher (choke) circuit to make sure its shutting off when you turn it off (maybe stuck enricher adjust slide thingy) but first thing i would do is get that airbox back on.
April 1st, 2013, 06:51 PM | #10 |
Join Date: Jan 2013 Motorcycle(s): Ninja 300R Posts: 181
or get some jets for a airbox delete
April 1st, 2013, 07:13 PM | #12 |
April 1st, 2013, 08:14 PM | #13 |
So I got the air box back on and was running frickin great. Once it warmed up though, it revs up to 4000 and won't come down until it cools off. Once it cools, it runs good. The only other thing I see is when I throttle it, it kinda hangs there and comes down slow.
April 1st, 2013, 08:20 PM | #14 | |
April 2nd, 2013, 12:47 AM | #15 |
adjust idle speed, make sure choke is not on. if choke is not working, assume its stuck on
Full throttle kills bike, throttle lag response. | Diegone | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 30th, 2014 03:25 AM |
[twisted throttle] - Visit the Twisted Throttle Open House & 10th Anniversary Party o | Ninjette Newsbot | Motorcycling News | 0 | April 13th, 2012 08:00 AM |
[twisted throttle] - Visit the Twisted Throttle Open House & 10th Anniversary Party o | Ninjette Newsbot | Motorcycling News | 0 | April 13th, 2012 07:40 AM |
[twisted throttle] - Visit the Twisted Throttle Open House & 10th Anniversary Party o | Ninjette Newsbot | Motorcycling News | 0 | April 12th, 2012 11:20 AM |
Throttle & Throttle Cable Smoothness | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | December 1st, 2009 01:50 PM |
