April 27th, 2012, 03:20 PM | #1 |
Thinking of changing front sprocket - any tips?
Looks like my chain will need replacing soon. According to most everyone, its best to change the worn sprockets at the same time. So I have to change the sprockets, but what about the ratio? Should I stick with the OEM 14-45 or go with a 15-45 or other?
I know that changing it like that will make the engine run slower, but does that really increase the MPG that much, or is it just negligible? Factory MPG is 70 mpg. It will definitely cut into my 0-60 runs. And if I do use a 15 tooth front sprocket, will I need an extra link in the chain? OR is 106 links still close enough? Is there a chart somewhere showing what ratios with how many links? Anybody been through this before? I mean, I like higher MPG, but I don't want to turn my Ninja into a low powered cruiser.
April 27th, 2012, 04:19 PM | #2 |
If you change to 15/45, the only thing that's going to change is first gear will feel longer. The rest of the time, you can just ride a gear lower than normal and get the same zippy feeling.
15/45 will be fine with the stock chain. 14/47 is also fine (and highly recommended by me for its grin factor) on the stock chain, but if I do it again, I'll get one with 108 links to make it easier to get the wheel on and off. The other thing to consider is just keeping the stock 14/45, and getting a rear tire with a 90 profile. That will get the same effect of lowered rpm's (check the speed @ rpm calculator on faq.ninja250 to play with different combos of tires/sprockets) |
April 27th, 2012, 05:52 PM | #3 |
I've already got the 90 profiles on their. I didn't notice much other than the speedometer was a little more accurate. Did you notice any difference in your MPG?
April 27th, 2012, 05:57 PM | #4 |
Plenty of threads in the similar threads list on the bottom of this page. Consensus, it's good.
2009 Ninja 250R SE Green Sport Touring Style: ZG ST; Symtec heated grips; RAM GPS w/ mUSB; DIY reshaped seat; DIY Givi E21 Sidecases; 15T sprocket |
April 27th, 2012, 06:28 PM | #5 |
Since it looks like the 15T sprocket uses the same size chain, I think it should be possible to get a 15T and then switch back to the 14T if its too big of a performance hit. I weigh over 200# so that is a factor too.
I did search for similar threads before I posted that, but none of those came up. According to some people in those threads, the 15T sprocket doesn't do much for MPG, but others say it does increase it slightly. So the general concensus as to whether it increases MPG or not is maybe.
April 27th, 2012, 09:19 PM | #6 |
nope. no difference in MPG's. Funny thing is, I didn't notice a difference in rpm's either when I switched to 90 profile tires. But I definitely noticed it when I when to 14/47, which is basically the same as switching back to stock size tires.
April 27th, 2012, 09:35 PM | #7 |
Join Date: Apr 2012 Motorcycle(s): 1990 Ninja 250 "Jolene" Posts: 68
I just changed out my chain and upped my gearing today (as in, just got back from a 100 mile test ride) to the 15/45 and I like it! First gear is actually usable in some situations other than parking, I've dropped about 750-900 RPM's at cruising speed so its less buzzy, and after just a short while got used to the gear ratios being further apart (yeah... i think thats the correct terminology...). If you want the same zippiness, just twist the throttle a little harder and wait a tad longer to drop into the next gear. No problems with hills either.
So far, I'd say if you spend any time cruising at 55+ on a regular basis it's a good option. Based on the reduced RPM's i would imagine mileage will go up, but only time will tell. Also, it's a piece of cake to do, and to reverse if you really don't like it in which case you're only out $20 and you've always got the sprocket if you plan on going on a long trip. |
April 29th, 2012, 02:39 AM | #8 |
You are correct with your assumption. I personally like it because it smooths out every gear a little and lets me get through a turn in 1st. Everything else after that to me is negligible.
April 29th, 2012, 10:07 AM | #10 | |
Excellent use of Ur time
Join Date: Jan 2012 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 4
April 29th, 2012, 10:12 AM | #11 |
April 29th, 2012, 10:26 AM | #12 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
When i first bought the bike i used to have alot of vibration and high rpms on the freeway so i changed it to the 15T in the front. It increased my MPG a bit around 2-3mpg more. Depends how u drive. Then i switched it to 15-42. Not much of a difference but in 6th gear every 1k is 10mph. So much easier to travel on the highway. And i have pods, efi, and muzzy and my bike is still quick . And the set up I am running the 15-42 is what alot of pregen track ppl run so they can maintain their top speed and powerband in the gears.
TO each his own :P. ......... install the efi kit too lol. quick edit: for the 15T front i had the stock 106 chain. With 15-42 i got a 104 chain and it fit perfectly...... perfectly lol.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
April 29th, 2012, 05:52 PM | #13 |
is there any need to rejet the carburetor if I switch to the 15T sprocket?
April 29th, 2012, 05:55 PM | #14 |
...no. those are two unrelated things,
April 29th, 2012, 06:37 PM | #15 |
nope
April 29th, 2012, 07:08 PM | #16 |
Ok, I just ordered a 15:45 set. I'll let you guys know how it works out.
April 29th, 2012, 07:11 PM | #17 |
dont forget to shim the crush drive especially since ur doing the rear sprocket
May 4th, 2012, 11:08 PM | #18 |
Join Date: Jul 2011 Motorcycle(s): 2019 Ninja 400, 2009 KLX250-SF, 2014 Zero S Posts: 269
I went to 15-44, and my gas mileage definitely, without a doubt, went up by at least 5 mpg. This is riding at a reasonable speed, and only going 65-70 on the freeway. Street riding is a little more comfortable with less shifting. But I do notice the wider spacing in the twisties, when you upshift there is less overlap in your powerband and it's just harder to find the right gear. Overall, it fits my style of riding.
May 4th, 2012, 11:10 PM | #19 |
I think people with aggressive throttle control may not see a difference in gas mileage b/c they are constantly pinning it and to accelerate at the same rate still takes the same amount of energy.
May 5th, 2012, 05:04 AM | #20 |
I ordered the 15-45 sprockets. Still waiting. My goal is to let it run at a lower RPM to hopefully make higher speeds easier on the bike by lowering the RPM. I've got about 18K on the original OEM set so its time to think about new ones. The old one has a tendency to slap around a lot which drives me nuts.
May 5th, 2012, 09:07 AM | #21 |
well with the front being 15T u will drop about 500rpms at every speed. Made 1st gear a bit more usable too,
May 5th, 2012, 04:32 PM | #22 |
My 45T came in today - still waiting on the the 15T. I compared the 45T to the stock one and I can't tell that there is any wear on it. Maybe I'm not looking at the right thing. The only difference I see is the dirt and grease on the OEM.
May 5th, 2012, 04:44 PM | #23 |
after 10k miles on mine rear it didnt look so much difference either. I think the teeth on the new sprocket were a bit beefier
May 5th, 2012, 04:50 PM | #24 |
The teeth on mine were a little sharky after 14,500 miles, but not super bad. The chain was what needed changed, so both sprockets went as well.
May 5th, 2012, 05:56 PM | #25 |
Here is the old and new side by side. I've got about 18K miles on them. I have been told that the front sprocket is the one that gets the most wear because there are fewer teeth. But on the back, I can't tell.
Right now I'm getting a lot of snapping sounds back there when I accelerate. Also an occasional repeating crackle that repeats at the chain rotation frequency.
May 5th, 2012, 06:03 PM | #26 | |
May 27th, 2012, 02:35 PM | #27 |
I finally got around to making installing both sprockets plus the new chain. There is a noticeable difference in RPM and not such a big difference in acceleration. In fact, with the 0-60 run, its possible now to do it with only two shifts. This saves a little time which may compensate for the lower gearing.
The front sprocket was in real bad shape. The slots were about double wide and the tips were bent over like little hooks. I wish I had inspected it regularly but its hard with the cover in the way. It should have been replaced at least 5K miles ago. The rear sprocket still looks like new. If I had replaced the front sprocket 5K miles ago, the OEM chain would probably still be good. The only problem I had/have is the master link. I wasn't able to figure out how to properly rivet the thing together so I went ahead and put the clip link on there for temporary. The clip link looks like it would fling off at any minute so I'm going to get the rivet link on there asap.
May 27th, 2012, 05:33 PM | #28 | |
And i like the clip type. alot easier to take off and put back on. I just put some silicone, the black stuff they put for oil pans, and it hasnt flung off since. I also put some safety wire too for extra protection.
May 27th, 2012, 06:19 PM | #29 | |
May 27th, 2012, 06:35 PM | #30 | |
My rivit is tight on the first pin and it is ok on the second. Its not loose. Thats why i used the silicon and safety wire. but yeah the better rivit tools does help.
May 27th, 2012, 08:43 PM | #31 |
I used the SM o- ring chain from cycle gear it was originally 120 links so I cut it down to 106 links. The regular chain tool worked fine for that. I will try to fix the the rivet link but if I cant Ill try the safety wire for sure.
May 28th, 2012, 06:32 AM | #32 |
Attaching a few photos of the link and sprocket. The clip link doesn't even look properly seated. I pushed it in as far as it would go. In the sprocket pictures you can clearly see the shark fin look. The sprocket had 19K miles on it when changed.
May 28th, 2012, 06:46 AM | #33 |
Join Date: Apr 2012 Motorcycle(s): 2003 Goldwing GL1800, 2002 Ninja 250, 2001 VFR800, 1999 Ducati 996 Posts: 107
Couple of comments....
1) That front sprocket is VERY hooked and totally worn out. 2) That clip on the split link is definitely not seated properly. You can see daylight between the pin and the shoulder of the clip, and on the second pin you can see where the arm of the clip is not seating. This will likely fly off in a hurry..!! |
May 28th, 2012, 06:50 AM | #34 |
Just yesterday I changed my sprockets to a 15 / 41 combo, using JT steel sprockets front and rear.
I commute daily and want a bike that has a more relaxed crusing speed. The 15/41 combo lowers revs nicely, about 1K rpm per every 10mph. Doesn't sound much but the bike is a different animal and feels so much more relaxed. If you want to accelerate, simply drop a gear or two. Like others have said, 1st is actually usable now. Not sure about the mpg component yet, but I will very soon find out as I begin my commute regime again tomorrow.... Dave. |
May 28th, 2012, 07:04 AM | #35 |
I used JT sprockets as well, but I am not certain about the quality of the front sprocket. The front sprocket that I got looked a lot like it was made by powder metallurgy. I could see absolutely no tool marks on the sprocket whatsoever. The rear sprocket looked more like it was laser cut from flat stock which makes for a much stronger sprocket.
For those reading this that don't know what I'm talking about, powder metallurgy is where metal parts are made by packing iron filings into a shape and then baking them in an oven for a little while. After baking, they stick together in the shape they were made into. The problem is that they aren't all that strong. More info. Having said that, I have no clue how other manufacturers do it or how they compare. It may be just fine for this application. I'll just have to keep an eye on it.
May 28th, 2012, 09:45 AM | #36 |
yea you need to get some needle nose plyers and if you cant with those something to squeze the link together. But yeah that clip isnt on all the way. And yea with a clip def put safety wire. And if you want some more safety put some silicone it will keep things from moving around like a clip from coming off.
May 28th, 2012, 12:03 PM | #37 |
After reading all the horror stories about using clip-type master links, I went ahead and put the rivet link back on. This time, I got it mushroomed out fair and will finish it off with a ball peen hammer later. Everyone says to do it that way anyhow. In the mean time, I put about 5 miles on it with no signs of it coming loose. I will feel better once its peened.
May 28th, 2012, 03:54 PM | #38 | |
Oh, well...
Changing my front light... Hard? | Jdb17 | 1986 - 2007 Ninja 250R Tech Talk | 6 | May 25th, 2014 09:48 PM |
thinking of changing my bikes colour scheme... | LoneRonin | 2008 - 2012 Ninja 250R Farkles | 4 | May 24th, 2012 07:53 AM |
front sprocket | miniguns167 | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 27th, 2009 11:59 AM |
In case you were thinking about changing your front sprocket... | M-Oorb | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 12th, 2009 09:40 PM |
Thinking about changing my oil change routine | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 14 | January 4th, 2009 07:55 PM |
