October 16th, 2011, 11:30 AM | #1 |
Join Date: Jul 2011 Motorcycle(s): 09' Ninja 500r 08' Ninja 250r Posts: 17
250r barely runs after K&N pod install
Ok i just installed K&N dual pod filter and shimmed my carb needles. Bike barely runs. It was chugging and basically wouldn't run under throttle, if i try to rev it up it gets to like 3k, starts to bog, then when i left off it dies.
Link to original page on YouTube. |
October 16th, 2011, 11:34 AM | #2 | |
October 16th, 2011, 11:45 AM | #3 | ||
ID = 0.1250" , 1/8" , 3.175mm OD = 0.3750" , 3/8" , 9.525mm thickness = 0.0400" , 1.016mm If you can't find #4 washers, try to get an assortment that is close in dimension. Those with 2.5 - 3mm inside diameter, and not being too much larger than 3/8"/9.5mm outside should be fine. The problem with carb adjustments is the complexity of the situation: one adjustment will affect idle, another adjustment affects acceleration, another affects mid-range, another affects top-end. And there's overlap between them. The old-time wisdom is to only change one thing at a time. This is hard to make yourself do. |
October 16th, 2011, 12:01 PM | #4 |
Watched your video on youtube. Sounds like it's running too rich.
Doesn't surprise me that it won't rev past 3 or 4 thousand. An overrich situation is made worse by the fact that the bike's ignition system is really ramping up the advance between idle and 4000 rpm (the pre-gen bike goes from 13 degrees BTDC at idle to 42 degrees BTDC at only 4,200 rpm). Also, if you've been it running at "black smoke" levels of rich you should pull the spark plugs and look at them. It's possible to end up with the plugs so carboned up that even if you guessed right and got the carbs perfect, the bike would still run like crap. The only way to know if you're correcting things with the carbs is to be sure that the bike is running on clean, properly gapped spark plugs. |
October 16th, 2011, 01:05 PM | #6 | |
Recheck your needles & shims and change your main jets or put the air box back in. |
October 16th, 2011, 01:08 PM | #7 |
Ridin Dirty
Join Date: Jun 2011 Motorcycle(s): 2011 white se 250r , 2008 zx6R Posts: 921
with no airbox and pod filters in you need more fuel.. my bike wouldnt rev past 7k when i did pod filters and 105 mains! needles were shimmed and evrything.. needed 110 mains. the mixture screw just leans/richens the throttle response.. like how fast it returns back to idle.. to lean it hangs before going back to idle, to rich it drops below the idle speed.. or vice versa, cant rember lol!
#1 |
October 16th, 2011, 04:27 PM | #8 |
Found the main issue. Pulled carbs again and found that the washers I'm using keep the spring retainer from holding needle down. Removed washers and it started and idled much better, took it for a quick ride, def needs jets (which you guys already knew lol)
got to find smaller o/d washers to shim needles and prob 110 jets. By now many screws are beginning to strip, gotta replace that hardware and carb to engine boot clamps. |
October 16th, 2011, 05:19 PM | #9 | |
The only screwdriver bit profiles that won't strip them are: Real JIS drivers (of course) and the other, believe it or not, is a small sized drywall bit. |
October 16th, 2011, 05:54 PM | #10 | |
Or... maybe it means you're burning some really high-resin BC-bud. |
October 21st, 2011, 04:50 PM | #11 |
Jets came in today so I ran home on lunch, swapped bikes and rode 250 back. Got 108 to 115 from jets r us. Started with first installing washers that actually fit, as opposed to ones that held spring hold down up, allowing needles to pop up. 2 washers to start. threw In the 115's to start, figuring I would work backwards rather than start at 108 and work up. Well it started great, once it warmed up I adjusted idle speed to about 16-1700, then tried blipping throttle and it basically hung at 3k. Turned screws all the way in and started backing them out little by little. Now the throttle drops from say 6k, unbearably to 2200 or so,then after 3 seconds or so it comes back to idle, ok I can live with that until I get more time to play with it. Drove much much better than before, still feels like a weak midrange, might go to 112s and ride again. Anyway, are mixture screws just for idle?
October 21st, 2011, 08:57 PM | #12 |
Join Date: Oct 2011 Motorcycle(s): ninja 250r, crf 50 Posts: 120
a hanging rev sounds lean.. have you done anything with the pilot jet? sounds like you need a bigger pilot. you can only do so much with the mixture screw.
October 25th, 2011, 02:33 AM | #13 |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
When I swapped out my airbox for the pods, I first tried the following
Factory Pro Stage 2 (very nice because it replaced those JIS screws with hex) Pilot: 40 Main jet: 110 Needle: clip in3rd, 2 washers, clip on top First run It would get really boggy around 7k. After less than a mile the engine cut and wouldn't start again. Don't know if maybe something was clogging the carbs or what, but I know it wouldn't start no matter what I tried. Pushed it home and jumped straight to 115 mains. Runs great now (slight hickup between 8-9k). I have a feeling it's running a little rich and I plan to try the 112.5 again now that the weather has changed a bit, but for now I'm happy with it's performance and not really in the mood to pull it apart. A little rich is better than a little lean. You should really consider a 40 pilot.
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
October 25th, 2011, 09:40 AM | #14 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Make sure the runners are completely open, Mine weren't at first and my bike barely ran
----> My Youtube! <---- Unregistered, watch my youtube page! |
Ninja 300 Pod Install | mattmid | 2013 - 2017 Ninja 300 Tech Talk | 28 | February 3rd, 2015 11:16 AM |
Ninja 300 K&N Air Filter How To Install Tutorial & Quick Review Video | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 12 | June 27th, 2014 07:15 PM |
K&N Pod filter | mwirrick | Ninjettes At Speed | 13 | January 10th, 2014 05:57 PM |
K&N Filter or Pod | jonthechron | 2008 - 2012 Ninja 250R Tech Talk | 6 | February 17th, 2010 12:07 PM |
Bike barely runs, HELP!! | JCCJMM_ | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 22nd, 2008 07:05 PM |
