#1 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
Grip Installation Trick/Tip
When you are installing new grips its best to tape off the throttler tube opening because when installing the new grips some glue mite get inside the tube and the handlebar itself thus glue'ing the tube to the handlebar i just used some duck tape that comes off clean
#2 |
cuz
after the levers came
#3 |
cuz
bar ends (weigh less than oem) http://www.ebay.com/itm/370085174359...#ht_500wt_1202
and yea i really felt that this have a better grip that oem idk if there new or what but this grips rock great grip .
#4 |
Internet Slut
Join Date: Sep 2010 Motorcycle(s): 04 FZ1, 07 FZ6 Posts: A lot.
Aquanet hairspray inside the grip not on the rube works rather well also.
#5 |
^ I used hair spray too when I transfered my stock grips to my woodcrafts. Also, a trick for getting the grip off the bike; have an air compressor handy. If you aim the air blast just right up the inside of the grip, it will float it off the handlebar for just a moment, and you can slip it right off. works wonders
#6 |
That rider dude.
Join Date: Apr 2011 Motorcycle(s): 2011 White Ninja 250 SE. Posts: A lot.
Another tip, if using grip glue such as from cyclegear or anything, wear gloves. Its a mess and gets on your hands if youre not careful. Ask me how I know. <
Mods: flushmount Led front binkers, diode mod, pazzo levers, clear tank pad, racing replica grips, bike monkeys integrated tal light, zx-2r vinyls, rearsets, red bar ends, and more red accented stuff. |
#7 |
Join Date: Aug 2011 Motorcycle(s): 05 Ninja 250 Posts: 68
Spray paint from a rattle can also works well.
To remove, push a screwdriver between the bar and grip then squirt WD40 and wriggle the grip back and forth, it will slide off easily. |
#8 |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
Nice tips. I've had so pro grips sitting on my desk for almost 6 months now. I didn't want to install on OEM bars when I had ordered some clip ons. (issues with getting clip ons in stock/shipped so I still don't have them)
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
#9 |
ex-ninjette.org guru :o
Join Date: Jun 2010 Motorcycle(s): 2003 SV1000 S Posts: 475
when i did my heated grips, i just used an air compressor with a nozzle attachment. shoved it under the grip, blasted with air and twisted and pulled. did the same to put them back on.
#10 |
Spray adhesive acts as a lubricant to get the grips on and then dries to keep them in place. No hits, no errors, no runs, err uh.. no mess, no gloves.
#11 | |
Norwegian dude
Join Date: Aug 2010 Motorcycle(s): Ducati 748 Posts: 120
![]() ![]() I used hairspray to make them stick, and abit hot soapwater to get them over the bar-ends since I didnt take them off while installing these. |
#12 |
cuz
the grip hasn't changed since i bought them very happy w/them
What Do I Need To Do? Installation Help | ilovejesus | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 7th, 2018 09:08 AM |
Pro Grip 724 Dual Density Road Grip | fmx | 2008 - 2012 Ninja 250R Farkles | 10 | May 5th, 2013 07:47 PM |
The GoPro Tape Trick | Jiggles | General Motorcycling Discussion | 22 | November 7th, 2012 07:49 AM |
Trick Italian Bits | kavo | Ninjettes At Speed | 17 | May 24th, 2012 01:04 PM |
Carb Sync Trick/Tip | WindMeUp | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 28th, 2010 08:30 AM |
