March 15th, 2023, 12:15 PM | #1 |
[webbikeworld.com] - 2023 Honda Fury [Specs, Features, Photos]
Click here for full story...
The 2023 Honda Fury: The Wild Child Contents The Fury carries on in the 2023 Honda lineup as a unique offering. Largely unchanged since the 2010 introduction as a Japanese alternative to American iron, the Fury remains only available in the USA. Sorry, Canada. Powered by a 1312cc V-twin engine, the focus is on low-end torque, stunning looks, and Honda quality. The front end is raked for the long chopper look, and the lines flow nicely down the teardrop tank to a low seat (26.9 inches) giving the perfect stance. The Fury comes in one color, Pearl Yellow, to make sure everyone sees you. The brakes come with standard Anti-Lock (ABS) to make sure you can slow down quickly and make sure everyone gets a good long look. The 2023 Honda Fury starts at $11,499 USD / $ N/A CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Honda Fury in one place. Model Overview General Info
2023 Honda Fury Specifications ENGINE Engine1312cc liquid-cooled 52-degree V-twin four-strokePower53.7 HPBore x Stroke89.5mm x 104.3mmCompression Ratio9.2:1InductionPGM-FI, 38mm throttle bodyStarterValve TrainSOHC; three valves per cylindeDRIVETRAIN ClutchTransmissionFive-speedFinal DriveShaftCHASSIS Suspension Front45mm telescopic fork; 5.1-inch travelSuspension RearSingle*shock with adjustable rebound damping and five-position spring-preload adjustability; 3.5-inch travelBrakes FrontSingle 336mm disc with twin-piston caliper; ABSBrakes RearSingle*296mm disc with single-piston caliper; ABSTires Front90/90-21Tires Rear200/50-18Fuel Tank Capacity3.4 gallonsColorPearl YellowELECTRICAL IgnitionDigital transistorized with electronic advanceSpark PlugsHeadlightTail LightDIMENSIONS Overall LengthGround ClearanceTrail92mm (3.6 inches)Wheelbase71.0 inchesRake (Caster Angle)32.0°Seat Height26.9 inchesCurb Weight681 pounds (Includes all standard equipment, required fluids and a full tank of fuel.)WARRANTY WarrantyTransferable, unlimited-mileage limited warrantyExtensionExtended coverage available with a HondaCare Protection Plan® 2023 Honda Fury Features STYLING CHOPPER STYLING The Fury is one of the most authentic, radically custom styled motorcycles that Honda has ever produced. It features a teardrop seamless fuel tank, an ingenious single-shock rear suspension system and an aluminum swingarm. EXHAUST The Fury’s engine features specially designed camshafts that also add to the unique V-twin sound and power-pulse exhaust sensations. RAKED STEERING HEAD A raked-out front end, stretched wheelbase and a hardtail-style rear frame all work together to give the Fury a long, low, lean look. And that long wheelbase is no illusion—the Fury stretches a full 71 inches between axles. UNIQUE WHEELS AND TIRES A fat rear tire is paired with a slim front tire, both wrapped around distinctive alloy wheels. PERFORMANCE V-TWIN ENGINE A powerful 1312cc, 52-degree V-twin engine with a single-pin crankshaft and dual balancers has plenty of torque, and the feel only a V-twin can deliver. FUEL INJECTION Forget about fiddling with a choke—the Fury’s fuel-injection system means no-hassle startups on cold mornings or at high altitudes. COMFORT LOW SEAT The Fury’s super-low seat height is an integral design element that fits in behind the slim and long fuel tank. DRIVETRAIN SHAFT FINAL DRIVE The shaft final drive is quiet, clean and has been uniquely integrated into the overall design. HANDLING HIGH-TENSILE STEEL FRAME The Fury’s high-tensile steel frame is the centerpiece to this machine’s open, minimalist chopper styling. It’s functional, too, delivering smooth ride quality and responsive handling. ANTI-LOCK BRAKING SYSTEM (ABS) Standard equipment on every 2023 Fury, anti-lock brakes (ABS) help you make confident stops under less-than-ideal conditions. 2023 Honda Fury Photos 2023 Honda Fury Videos The Honda Fury! Factory Chopper Or Imitator Cruiser? 2023 Honda Fury Links Honda Websites Other Links The post 2023 Honda Fury [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2023 Honda CB500F [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | March 15th, 2023 11:37 AM |
[webbikeworld.com] - 2023 Honda CB650R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | March 15th, 2023 11:37 AM |
[webbikeworld.com] - 2023 Honda CB1000R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | March 15th, 2023 11:13 AM |
[webbikeworld.com] - 2023 Honda Goldwing [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | March 15th, 2023 08:21 AM |
[webbikeworld.com] - 2022 Honda Fury [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2022 02:22 AM |
