November 19th, 2013, 10:14 AM | #1 |
Weight
How light can a pre-gen be with keeping full body work and all parts needed for street use?
I know the stock exhaust, centerstand and grab rail are the big things to reduce weight but how much lighter is aftermarket bodywork? |
November 19th, 2013, 10:25 AM | #2 |
Bass Master General
If it's for street use, as in city riding, take the fairings off, you won't loose much in aerodynamics at city speed and you'll reduce more weight than fiberglass fairings giving better power to weight - drag and it's cheaper.
LOTS of threads on here about making a bike lighter, LOTS, try researching them first. |
November 19th, 2013, 10:49 AM | #3 |
Join Date: Apr 2013 Motorcycle(s): 02 ex250, 07 HD xl1200n, 69 ct90 Posts: 28
Got mine down to 310 with a full tank... she's butt ugly though
November 19th, 2013, 11:22 AM | #4 |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
Nice job, SDx!
On our pregen, we removed almost all the plastic and its supporting metal, a bunch of frame tabs, a couple of inches of subframe, and the seat latch hardware, and we used aftermarket lighting, instruments, handlebar and mirrors. All the stuff we removed weighed more than 30 lbs. The new stuff weighed about 6 lbs. Stuff we would do if we had the money and didn't need to carry a passenger or ride in rain: Aftermarket exhaust, airbox delete, lithium battery, lighter tires, passenger peg and bracket removal, frame bob, removal of both fenders. Check it out at: http://www.ninjette.org/forums/showthread.php?t=117501, http://www.ninjette.org/forums/showthread.php?t=117957, and http://www.ninjette.org/forums/showthread.php?t=120841 |
November 19th, 2013, 11:36 AM | #5 | |
November 19th, 2013, 12:15 PM | #6 |
Yes, all the stock pieces, except the new brake line. The Renthal bar is a few inches wider than the stock setup, so we had to reroute some of the control wiring behind the fork tubes, and cut the fairing stay tab off the steering head to avoid interference with the clutch cable. The clutch cable still runs forward of the top triple clamp.
If you used a narrower bar (like a Ninja 650 or Z1000 bar), you wouldn't have such issues. Clip-ons are a lot easier. |
November 19th, 2013, 02:52 PM | #7 |
clipons aren't really an option for the type of roads I ride on, too bumpy and too much debris... I know you mentioned it in one of your threads, but whats the OD on the bars and any hints on drilling the holes?
TY, Steve |
November 19th, 2013, 03:16 PM | #8 |
They're standard 7/8" bars.
I drilled mine on the throttle side (which took a long time, because I don't have a drill press), but it isn't necessary. If you grind down the lugs in the switch housings and put a piece of double-sided foam tape on the bar where the housing is located, the controls will be very secure. The hole-and-lug system works well at the factory, but it isn't strictly necessary to secure the controls. Most other brands don't use lugs and holes. If you really want holes, you can use bars from other Kawasaki models, like the Ninja 650 or Versys, which have them (and threaded bar-end lugs for weights or mirrors). The Ninja 650 bars are also narrower than the Renthal bars, so you may not have to reroute any wires. |
November 19th, 2013, 03:49 PM | #9 |
Actually I was inquiring about aligning the holes in the triple tree
November 20th, 2013, 07:41 AM | #10 |
Oh. I made a cardboard jig for that. It's very soft aluminum, and easy to drill. You have to be sure to space the holes so as to leave enough room for the nuts underneath.
November 20th, 2013, 10:09 AM | #11 |
bumpy + debris = clipons aren't an option? Explain please because I don't follow.
My MTB bars + seat drop is much more aggressive than my ninjette, and I take that on trails that are full of bumpy + rocks + drop-offs + obstacles. For drilling holes in the triple to mount upright bars, do some math, mark your centers, and do it on a drill press or mill. It will be a much better hole and will be much easier than doing it by hand. |
November 20th, 2013, 10:17 AM | #12 |
It would be great if someone could make 7/8" bar mounts that bolted to the stock riser area. Wouldn't have to cover the fork tubes, so it wouldn't require too much aluminum. Maybe Bigballsofpaint could rig up something, as he offered in
http://www.ninjette.org/forums/showt...&highlight=cad |
November 20th, 2013, 10:52 AM | #13 |
November 20th, 2013, 10:55 AM | #14 |
Let me rephrase that... I find clipons... uncomfortable.
November 20th, 2013, 03:12 PM | #15 |
Ah, that makes more sense.
November 20th, 2013, 05:27 PM | #16 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Out of curiosity what is the 250s weight without fuel stock?
November 21st, 2013, 07:46 AM | #17 |
November 21st, 2013, 06:27 PM | #18 |
Thats what I saw listed as dry weight. Manufacturers can cheat that by doing all sorts of things. Removing the battery, absolutely no fluids(oil coolant etc) and ever tires are sometimes included in that because they are a consumable. Anyone have an actual self tested one with their own pregen? Even a race bike would give a better idea.
November 21st, 2013, 06:31 PM | #19 |
Actually, that doesn't seem out of line. It's spec'd at 304 dry/355 wet.
It holds 4.8 gallons full, plus oil. A gallon of gas is about 8 lbs, so that's 38 lbs in just gas. Add two quarts of oil, coolant, and brake fluid, I could see that being about the correct dry weight without trickery. |
November 21st, 2013, 06:49 PM | #20 |
Did cycle world or sportrider ever do a test on the pregen that we could refer too?
[motorcyclistonline] - Weight, Weight, Don’t Tell Me | Cranked | Ninjette Newsbot | Motorcycling News | 0 | July 17th, 2014 09:40 AM |
Too much weight on bars? | Malicious Logic | Riding Skills | 14 | November 21st, 2012 09:51 PM |
[topix.net] - Husqvarna 900: power, weight and power-to-weight | Ninjette Newsbot | Motorcycling News | 0 | June 30th, 2011 03:30 PM |
[hell for leather] - Husqvarna 900: power, weight and power-to-weight | Ninjette Newsbot | Motorcycling News | 0 | June 29th, 2011 09:20 PM |
Weight Reductions | spencerkro | 2008 - 2012 Ninja 250R Tech Talk | 13 | April 6th, 2011 07:22 PM |
