Old July 25th, 2012, 08:05 AM   #1
edxmon
edxmon's Avatar
Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013)
Fixing fairing cracks v. JB weld an option?
1" crack above the "Ninja" sticker on the right side. It does't run all the way to any edge of the fairing, but I'm afraid it'll keep growing due to vibrations and such. The two sides of the crack are a bit offset so I would need to hold it while it dries to have the crack glued evenly. I was thinking of using JB weld on the inside of the fairings. Has any one tried this? I'd really like not to use heavy duty staples or screws to secure it while it dries. Any ideas suggestions?
I searched, but couldn't find a similar thread, let me know if I missed a DIY or a thread.
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips
edxmon is offline   Reply With Quote
Old July 25th, 2012, 08:40 AM   #2
dubojr1
dubojr1's Avatar
http://www.ninjette.org/forums/showthread.php?t=42690
Old July 25th, 2012, 08:47 AM   #3
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
I would not use JB Weld. It's much too hard once dry and the fairing will just end up cracking again. They make plastic specific adhesives and epoxies that actually fuse the two pieces back together.
k-os is offline   Reply With Quote
Old July 25th, 2012, 09:29 AM   #4
sc37
sc37's Avatar
Motorcycle(s): Currently: 2012 Honda NC700X; Previously: 2010 Ninja 250R
I used the JB Weld epoxy putty. It has worked fine so far. I just liked it better than anything else cause I could knead it and squish it wherever I wanted. Easier to work with something solid than liquid. I didn't even remove the fairings. I just stuck my arm down past the handlebars and worked the stuff in and around the crack.
sc37 is offline   Reply With Quote
Old July 25th, 2012, 11:45 AM   #5
edxmon
edxmon's Avatar
Originally Posted by dubojr1 View Post
YES! I knew I had seen this before, thanks
Old July 25th, 2012, 06:09 PM   #6
MorrisMeng
Motorcycle(s): 2011 Ninja 250R SE
Since you have a offset needs holding, I think soldering gun might be a easier choice. Because it hardens instantly.
I had similar problem with a much larger crack. I used soldering gun to hold them in place. And then used JB weld and fiberglass cloth to make it stronger.
MorrisMeng is offline   Reply With Quote
Old July 25th, 2012, 06:28 PM   #7
edxmon
edxmon's Avatar
I don't have a soldering gun. Do you mean like "tack welding" by melting the crack together at spots? That's pretty clever, but I lack the tool
Old July 25th, 2012, 06:47 PM   #8
MorrisMeng
yeah.
I used soldering iron on several spots just to hold them togeter.
NADA option: Fairing-Full???? Han Solo 1 General Motorcycling Discussion 27 February 26th, 2014 04:11 PM
Going to weld on spool mounts, Sipper' 1986 - 2007 Ninja 250R Tech Talk 2 November 26th, 2013 04:28 PM
Installed a tank without holes, a fairing with no cracks, and the gauges too!! verboten1 1986 - 2007 Ninja 250R Farkles 2 August 26th, 2013 01:13 PM
Anyone Know of any Good Fairing Repair Kits for Cracks? meehow09 2008 - 2012 Ninja 250R Tech Talk 2 April 20th, 2011 10:27 AM
fixing broken fairing??? Greg_E 2008 - 2012 Ninja 250R Tech Talk 8 August 23rd, 2009 07:47 AM
