September 20th, 2009, 10:44 PM | #1 |
How do you get your bike onto the rear stand?
I recently got a rear stand and a set of spools for my bike, and I'm having a hell of a time using it. I've watched a few youtube videos showing people who are used to using the things doing it, but I still need a little help.
Do you put the bike into 1st gear, or leave it in neutral? Do you lock the front brakes on? I assume I'm doing something wrong, but the only way I can get it to remotely work as expected is if I use my foot to block the wheels on the stand from rolling backwards while I lift/push. Even then, when I get the bike up to the highest point, it doesn't feel stable and I chicken out and put the bike back down onto the kickstand. The damn stand is mocking me right now. I can hear it. |
September 20th, 2009, 11:23 PM | #2 |
What type of rear stand is it? I've used Pit Bulls for years, and once you get the hang of it it's no trouble at all. Put the rear stand in position, put it under the left spool, and start pushing the bike up from a leaning position to closer to straight up and down. With your right hand, maneuver the stand however it needs to go to fit into the spool on the right side of the bike. This will only work if the bike is straight at this point. If the rear stand is put in close to the right place in the beginning, you shouldn't need to move it much at all for the right spool to be sitting in its carrier.
Once both spools are in their carriers on the stand, just push down swiftly on the stand and the bike will pop right up. The bike shouldn't be in gear, and while I've heard that some people clamp on the front brakes, I've never felt the need. The only way it goes bad is if the stand isn't positioned correctly under the spools. The most important part is to confirm right before lifting that yep, both spools are sitting in their carriers A-OK. If you scroll down to the very bottom of this page, there are a few more links of rear stand-related threads that should have some similar instructions, perhaps even a bit more detailed.
September 21st, 2009, 04:10 AM | #3 | |
Also... what stand are you trying to use? Better yet, how tall is your stand from the floor to where the spool would be sitting if the bike was on it? The taller the stand (higher lift) the more difficult to use. One of my stands is a $39 Harbor Freight (the black stand) and weighing in at just under 200 lbs, it was all I could do to get the bike up onto the stand (needed an assistant to hold the bike upright)... I had to bounce my weight on it. Once the bike was on the stand there had to be like 8-10 inches clearance between the rear tire and the ground. I shortened this stand about 2.5 inches and now I pop the bike up onto it by myself, with no problems. |
September 21st, 2009, 09:06 AM | #4 |
It's a little easier if you put a block under the kickstand first. A 2x4 works fine.
This raises the bike up closer to vertical so it's easier to line up the right side support. There's also less of that unnerving tipping motion as the bike stands up. Push down and forward. The bike will move, but it shouldn't move that much. I don't block the wheels or leave it in gear. When lowering the bike back down, I hang on to the rear end to make darned sure it tips to the left and I've got control of it as I lower it back onto the kickstand. Why not enlist the aid of a helper while you get used to it? |
September 21st, 2009, 09:29 AM | #5 |
Join Date: Dec 2008 Motorcycle(s): 2008 Ebony Ninja 250R Posts: 137
I will just balance the bike by holding the strap on the passenger seat with my left hand and tilting the stand with my right.
Posted via Mobile Device |
September 21st, 2009, 09:43 AM | #6 |
September 21st, 2009, 10:46 AM | #7 | |
IC2(SW)
Dont be chicken, once the stand is on the spools. The bikes not gonna tip over |
September 21st, 2009, 08:50 PM | #8 |
Live Life
Join Date: Nov 2008 Motorcycle(s): 2009 Green SE Ninja 250 Posts: A lot.
What Andrew said - that technique works great. With the 2x4 you will be able to see that the right spool is going to line up and it's all lift, no leveling and then up. Use a friend the first few times if you are still uncomfortable.
- ATGATT - Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots |
September 24th, 2009, 08:46 AM | #9 |
Join Date: Jun 2009 Motorcycle(s): 06 Ninja 650R, 08 Ninja 250R, 00 Aprilia SR50 (dead) Posts: 94
I think Pitbull makes a rear stand where the handle is forward now, allowing you to raise the bike from the side...Cyclecat before they went under had a cool stand which would grab the bike while over on its stand, straighten it and raise it all in one motion...
The key is go buy a bike master front stand, the kind where you ride in and get off, they are great.... |
September 24th, 2009, 09:43 AM | #10 |
Join Date: Jul 2009 Motorcycle(s): 2009 Ninja 250R Posts: 157
I ask my girlfriend to pick up the rear of the bike while I slide in the stand. I'm old and don't want to hurt myself.
www.edmcqueen.com |
September 25th, 2009, 09:02 PM | #11 |
noob in training
Join Date: Aug 2009 Motorcycle(s): '08 Ninja 250R (sold) '05 SV650S Posts: 175
Kind of off topic but what's the advantage to a spool stand over a swingarm stand?
September 25th, 2009, 10:09 PM | #12 |
A rear stand is always lifting the swingarm up. One with spool carriers lifts up from spools you install on the swingarm. If a bike doesn't have spools, the stand instead lifts from the bottom of the swingarm. Spools are much more secure, at least when lifting, as they sit in carriers and can't move fore or aft. Without spools it takes much more concentration and care that the paddles are aligned properly and will lift the swingarm (and the bike) without it tipping to one side or the other.
September 26th, 2009, 09:24 AM | #13 | |
Join Date: Nov 2008 Motorcycle(s): 2011 Honda CBR250R Posts: 585
I have a T-Rex and I can hook a spool, pull the bike upright to engage the opposite spool and then use my foot to push down on the handle of the stand until the rear end is up, keeping one hand on the bar and one on the saddle. Takes a little practice, but there's no danger of the bike getting away from me. |
[sportrider - latest stories] - Motorsport Products Rear Sport Bike Stand | Ninjette Newsbot | Motorcycling News | 0 | February 5th, 2013 07:50 PM |
Does the Oxford Paddock rear stand fit this bike? | joyinc | General Motorcycling Discussion | 8 | April 3rd, 2010 02:06 PM |
Can you lift the bike without a rear stand? | Cedilla | 2008 - 2012 Ninja 250R Tech Talk | 33 | January 3rd, 2010 11:15 AM |
How not to drop the bike when using a rear stand! | g21-30 | General Motorcycling Discussion | 13 | July 2nd, 2009 06:50 AM |
