Old June 20th, 2011, 12:30 PM   #1
theredsox
ninjette.org user
Motorcycle(s): 2010 Ninja 250r (Blue)
Front brake bore size?
Hi everyone. I'm buying a custom lever system for my 2010 Ninja 250r because of a disability I have. I will have both the front brake and clutch lever on the right side of the bike. The company I'm trying to order the parts from today asked me a couple specific questions. Unfortunately the motorcycle shop I bought my bike from and currently has my bike, is closed on Mondays. I hope someone here might know/verify the answer to these.
Q: Bore size of front brake master cylinder?
A: 62.0 x 41.2mm
Q: Is it a hydraulic clutch?
A: No, cable-actuated
Q: Assuming it is a cable clutch; is it nipple or lasso?
A: From the 'DIY Replacing the clutch cable' thread for changing a clutch cable, doesn't look like anything is lasso'd so going to say nipple
Q: Assuming it is a cable clutch; what is the distance between the lever pivot point and center of nipple/lasso?
A: Again looking at the DIY, there was a convenient picture of the lever with a ruler by it. It looks like 20-30 mm.
Thank you for the help.
~Brandon
Last futzed with by theredsox; June 20th, 2011 at 03:42 PM. Reason: Think I found the answers
theredsox is offline   Reply With Quote
Old June 20th, 2011, 03:44 PM   #2
theredsox
ninjette.org user
I think I found all the info I needed from the 'DIY Replacing the clutch cable' thread. Would be comforting to have confirmation though as I currently don't have my 2010 ninja yet to look at or the manual. Spending $1500 and getting the part from England, so really want to make sure it is right the first time.
Old June 21st, 2011, 01:53 PM   #3
HKr1
IC2(SW)
HKr1's Avatar
A: 62.0 x 41.2mm
I didnt see it in the 250r manual...... But, stock master cylinder pistons are like 14mm & 16mm.
Old June 21st, 2011, 03:00 PM   #4
theredsox
ninjette.org user
Thanks HKr1. The 62 x 41.2 I saw is probably engine cylinder and not what I want. 14 and 16mm sounds realistic.
Smallest possible front sprocket size SvenW 2008 - 2012 Ninja 250R Tech Talk 2 August 22nd, 2013 05:54 AM
Front Master Cylinder Size FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 3 August 14th, 2013 02:38 PM
Front caliper bolt size Vergil 2008 - 2012 Ninja 250R Tech Talk 3 June 16th, 2013 05:35 AM
Front brake master cylinder piston size old3 General Motorcycling Discussion 3 November 16th, 2012 03:39 PM
What size ratchet to take off front sprocket? M-Oorb 2008 - 2012 Ninja 250R Tech Talk 15 January 12th, 2009 02:42 PM
