March 9th, 2014, 03:20 AM | #1 |
Lowsided 1 month in
So I had my first crash today. Was raining for around 10 minutes before I left home and came up to the lights taking a right turn and the rear wheel lost traction and I lowsided :'(
Bike slid for around 15 m, and I slid for around 10. I was wearing all my gear(Full face helmet, Jacket, pants, full gauntlet gloves and tall riding boots). Picked the bike up and rode to football training and played for 3 hrs lol Bike is cosmetically damaged, exhaust and indicator got a nice sanding off, while the engine case has deep scratches on it and looks pretty bad. I was doing around 40 kmph, nearly the same speed I do in the dry. I'm not sure if it was the speed, the wet, oil/painted line/metal grate, fact that the rear tire was brand new or my general inexperience. Pic related |
March 9th, 2014, 07:35 AM | #2 | |
Sorry to read about this and painful to watch that picture.
Good that you had skin and head protection. I guess this is part of feeling so alive. Quote:
Oil and dirt accumulated on the road mix with the water and makes a slippery mess. Waiting 30 minutes is the safe thing to do. If you cannot wait, then reduce your normal speed in half. Not knowing what took you down is bad; you must see with enough anticipation and evaluate each square inch over which you plan on rolling.
March 9th, 2014, 07:40 AM | #3 |
Private Joker
MOTM - Mar '14
So what you're saying is that you did the same speed you do in dry on a brand new tire in the wet? Without knowing the corner I can't say whether that should be possible or not but new tires and wet are two different levels of lack of traction added together so you should have been going slower than you were used to. Did you ride over any painted lines? those tend to have a ridiculous lack of traction in the rain as well and the combination of all 3 factors could have you on the ground immediately if you aren't careful. The engine casing should be fine, just check it to make sure it's not leaking oil. If it is then just replace it, it doesn't take too much effort.
March 9th, 2014, 08:10 AM | #4 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
The important thing is you're OK. And the bike is rideable (with a little work on indicators, and the like).
You're learning stuff. That's why it's good to start out on older, cheapish bikes. And wear the proper gear. |
March 9th, 2014, 08:39 AM | #5 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
That's okay, I lowsided one week in.
March 9th, 2014, 11:19 AM | #6 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
Long as you are ok that is all that matters.
March 9th, 2014, 11:45 AM | #7 |
Your face
Join Date: Jul 2013 Motorcycle(s): 2014 Honda CBR650f Posts: A lot.
It sounds like the issue was all of the above. Sorry to hear about the crash though
"even a proper fitting helmet can 'get loose'" -csmith |
March 9th, 2014, 10:48 PM | #8 |
Yeah should have done that turn way slower now thinking about it. New tires in the rain don't have much grip. But my confidence is kinda low on corners now, I'm afraid to lean even in the dry because I'm not sure the tires will grip the road properly :/
March 10th, 2014, 05:25 AM | #9 | |
You ride in the now and there is enough grip between your rubber and dry clean asphalt as to support your weight plus the weight of the bike sideways. Please, read these: http://www.ninjette.org/forums/showthread.php?t=119958 http://forums.superbikeschool.com/in...showtopic=4035
March 11th, 2014, 06:27 AM | #10 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Heal up and ride again...
March 11th, 2014, 10:11 PM | #11 |
Join Date: Mar 2012 Motorcycle(s): 2008 Ninja 250r Red Posts: 93
glad your alright and were geared up.
I low slided one month in also. there was construction, on the right side of the road. which forced a lane to merge. once the cones cleared a car from the left lane turned right and knocked me off my bike. he bumped me with his passenger door. i had no insurance at the time. so automatically it was my fault and the bill was over 4k for his damage. Ugh. lesson learned though. evaluate as much as you can at all times. safe riding man! |
March 12th, 2014, 01:51 PM | #12 |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
Glad you're ok.
Just out of curiosity; do you recall suddenly closing the throttle or braking during the turn? I ask that, because, wet roads offer a nice amount of grip. They are just less forgiving if you do something which suddenly demands a ton of grip (like brake or chop the throttle while leaned over). Of course, if it was the first time it had rained in a while (creating that slippy grimey surface @Motofool mentioned), or there was oil, a metal drain cover or painted road markings, that would drastically reduce the grip making it unsafe to give the bike anything more than a very gentle lean angle. |
Lowsided | Old Lemon | !%@*#$%!)@#&!%@ I crashed! | 6 | April 26th, 2013 01:03 PM |
Lowsided :( | KawiKid860 | !%@*#$%!)@#&!%@ I crashed! | 7 | May 7th, 2012 10:30 AM |
Lowsided... | TheTopher | !%@*#$%!)@#&!%@ I crashed! | 9 | May 4th, 2012 08:43 AM |
I lowsided | the big mike | !%@*#$%!)@#&!%@ I crashed! | 12 | September 25th, 2011 06:49 AM |
I lowsided | n4v1n | !%@*#$%!)@#&!%@ I crashed! | 63 | August 4th, 2009 09:12 AM |
