February 5th, 2011, 11:09 AM | #1 |
Side light bulb
Does anyone know how the side light bulb comes out? I got access to the rear of the headlamp and upgraded the headlamp bulbs but I couldn't get the side light bulb out
I was hoping to fit an LED side light bulb if possible! Thanks Dave |
February 5th, 2011, 01:22 PM | #2 |
You mean the turn signals? I think there is a small screw holding the housing together.
February 5th, 2011, 09:24 PM | #3 |
Join Date: May 2010 Motorcycle(s): 2010 Kawasaki Ninja EX250 Special Edition Red/Black Posts: 455
It is just a screw holding the housing together. Beware though, if you're going to add in led turn signals, you are going to have to change your turn signal relay as well. You'll want to buy an electronic relay. You can find them at your local auto store.
'10 Ninja 250R SE Red/Blk Mods: Projekt D FE, Protons, HB Blk Windscreen, HIDs, TBR Blk Series Slip-On, Shogun Sliders, Solo Cowl, Integrated Tail Light, Gls Blk Rear Fender, Red Accents |
February 6th, 2011, 01:31 AM | #4 | |
Dave |
February 6th, 2011, 01:41 AM | #5 |
Join Date: Apr 2010 Motorcycle(s): 2009 Honda CBR600RR Posts: 633
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja |
February 6th, 2011, 02:03 AM | #6 | |
February 6th, 2011, 06:45 AM | #7 |
We don't have a bulb located there on the U.S. model, however if you take off the front cowl you may be able to see how to access it better. I know in certain parts of Europe, cars have one dim rear light a one dim front light on at night when parked on the street. Is that the same in the U.K.?
February 6th, 2011, 11:46 AM | #8 | |
I took the lower cover off to change the headlamp bulbs but could not remove the side lamp bulb. I could not see up there but I did not want to break anything. Dave |
February 6th, 2011, 12:17 PM | #9 |
If you can reach your hand up in there you may be able to feel it. My guess is it may be a wedge type bulb. They simply twist out like the bulbs in the gauge dash.
February 7th, 2011, 06:10 AM | #10 | |
Dave |
Light bulb and Gauge bulb options | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 11 | August 21st, 2014 10:06 AM |
Tail light? Fuse or bulb? | Løckøut | 1986 - 2007 Ninja 250R Tech Talk | 10 | September 30th, 2013 10:17 AM |
Dual Filament bulb sockets for side-of-tail-light?? | kxpower? | 1986 - 2007 Ninja 250R Farkles | 19 | September 6th, 2013 04:38 AM |
Tail Light + Brake Light Not Working (Bulb Replaced) | JayZE302 | 2008 - 2012 Ninja 250R Tech Talk | 11 | August 8th, 2012 05:03 PM |
How long does it take to change a light bulb? | Den | 2008 - 2012 Ninja 250R Tech Talk | 12 | August 12th, 2011 09:15 PM |
