October 15th, 2012, 02:01 PM | #1 |
Join Date: May 2012 Motorcycle(s): 2001 Ninja 250 Posts: 77
very quick question on idle mixture screw
What is the correct order to install the idle screw parts. I got my rebuild kit today and it has screw, spring, washer and oring. What is the correct order?
http://faq.ninja250.org/images/f/fc/...ETOR_PARTS.png section 16014 I ask because I would assume oring is black in the diagram BUT the bowl oring is clear not solid black-means its an oring? Anyone? And I'll be sure to reinstall the cover plugs.
1` |
October 15th, 2012, 02:02 PM | #2 |
I ask because my stuff was missing.
1` |
October 15th, 2012, 03:19 PM | #4 |
O-ring, washer, spring, needle. The washer protects the O-ring from the spring. Diagram here: http://www.ronayers.com/Fiche/TypeID...rburetor_Parts
October 15th, 2012, 04:03 PM | #5 | |
1` |
October 15th, 2012, 05:52 PM | #6 |
Yep, that's it. Now the hard part is getting the thing back in there without it flipping on you.
what is the best idle screw mixture | vmax | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 1st, 2017 10:45 AM |
Idle Mixture Screw Problem | gogoKawi | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 23rd, 2013 07:07 PM |
Adjusting the Idle Mixture Screw | conrya5 | 2008 - 2012 Ninja 250R Tech Talk | 22 | March 18th, 2013 05:03 AM |
Idle Mixture adjustment screw Q | indr | 2008 - 2012 Ninja 250R Tech Talk | 1 | December 2nd, 2010 09:36 PM |
Idle mixture screw question after jet install... | diablo250 | 2008 - 2012 Ninja 250R Tech Talk | 12 | September 26th, 2010 09:10 AM |
