November 4th, 2014, 03:00 AM | #1 |
[visordown.com] - Kawasaki Z300 unveiled
KAWASAKI has just unveiled it's third surprise new sub-500cc bike for 2015, the Z300. A naked version of the Ninja 300 using the same tubular steel chassis and 296cc parallel-twin engine, it makes a claimed 39hp and 19.9lbft of torque. The engine shares identical specifications with the Ninja 300's revvy motor, while Kawasaki says the styling is inspired by bigger machines in the Z range. The wheels, brakes and suspension components are also the same as the Ninja 300's. That means it's got 37mm forks, a preload adjustable shock and a single 290mm petal-style front brake disc with a twin-piston caliper. Straight handlebars replace the Ninja's clip-ons for a more relaxed riding position. Visordown predicted the arrival of the Z300 back in January 2013, when the Z250 – a smaller-bore version of the same bike – was unveiled for Asian markets. The Z300 was unveiled today at the Eicma Milan motorcycle show alongside Kawasaki's two surprise new single-cylinder offerings, the Ninja 250SL and Z250SL. The Z300 has a kerb weight of 168kg or 170kg with optional ABS. It's expected to cost around £5,000 and comes in green and metallic black or grey and metallic black. Here are the full specifications from Kawasaki's release: ENGINE ER300AFF/BFF Type Displacement Bore and Stroke Compression ratio Valve system Fuel system Ignition Starting Lubrication Liquid-cooled, 4-stroke Parallel Twin 296 cm3 62.0 x 49.0 mm 10.6:1 DOHC, 8 valves Fuel injection: φ32 mm x 2, with dual throttle valves Digital Electric Forced lubrication, wet sump DRIVETRAIN Transmission Final drive Primary reduction ratio Gear ratios: 1st 2nd 3rd 4th 5th 6th Final reduction ratio Clutch 6-speed, return Chain 3.087 (71/23) 2.714 (38/14) 1.789 (34/19) 1.409 (31/22) 1.160 (29/25) 1.000 (27/27) 0.857 (24/28) 3.000 (42/14) Wet multi-disc, manual FRAME Type Wheel travel: front rear Tyre: front rear Caster (rake) Trail Steering angle (left/right) Tube diamond, steel 120 mm 132 mm 110/70-17M/C 54S 140/70-17M/C 66S 26o 82 mm 35o / 35o SUSPENSION ER300AFF/BFF Front: Rear: φ37 mm telescopic fork Bottom-Link Uni-Trak with gas-charged shock and adjustable preload BRAKES Front: Type Caliper Rear: Type Caliper Single φ290 mm petal disc Single balanced actuation dual-piston Single φ220 mm petal disc Dual-piston DIMENSIONS Overall length Overall width Overall height Wheelbase Ground clearance Seat height Curb mass Fuel capacity 2,015 mm 750 mm 1,025 mm 1,405 mm 145 mm 785 mm 168 kg (ER300A) 170 kg (ER300B) 17 litres PERFORMANCE Maximum power Maximum torque 29.0 kW {39 PS} / 11,000 min-1 (EUR) 27.0 Nm {2.8 kgm} / 10,000 min-1 (EUR) Related Content Kawasaki's new ER6-powered cruiser: the Vulcan S New Z1000: More pictures New Z1000: specifications revealed Kawasaki Z1000: first official pictures and specs Kawasaki Z250 revealed Click here for full story...
[motorcycle.com] - 2014 EICMA: 2015 Kawasaki Z300 Preview | Ninjette Newsbot | Motorcycling News | 0 | November 7th, 2014 12:00 PM |
[motorcyclenews.com - news] - MILAN SHOW: Kawasaki go naked with new Z300 | Ninjette Newsbot | Motorcycling News | 0 | November 4th, 2014 11:20 AM |
[motorcyclenews.com - news] - MILAN SHOW: Kawasaki go naked with new Z300 | Ninjette Newsbot | Motorcycling News | 0 | November 4th, 2014 05:21 AM |
[visordown.com] - Kawasaki Ninja H2 unveiled | Ninjette Newsbot | Motorcycling News | 0 | November 4th, 2014 03:00 AM |
[topix.net] - Kawasaki Z300 for U.S.?: Kawasaki Launches Naked Z250 in Indonesia | Ninjette Newsbot | Motorcycling News | 0 | January 31st, 2013 04:50 PM |
