October 26th, 2012, 09:54 AM | #1 |
Fast-Guy wannabe
MOTM - Jan '13
RojoRacing IPhone mount
Messing around with this today since my new phone has turn by turn navi now. This is just the prototype but I should have a final product by the end of the day. This Sundays group ride should prove to be a good test for it.
October 26th, 2012, 10:00 AM | #2 |
Jigglin' your Jiglets
MOTM - Apr '13
Interesting, is it going to be universal enough to fit different size cases?
October 26th, 2012, 10:01 AM | #3 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Did #74 just buy a new R6? LOL
October 26th, 2012, 10:12 AM | #4 |
Buy some big o-rings to slide around the phone and your mount! They're unobtrusive enough so they don't disturb anything you're looking at, but work well!
October 26th, 2012, 10:20 AM | #5 | |
Fast-Guy wannabe
MOTM - Jan '13
@Jiggles its a precise fit so I'm still working on adapters. |
October 26th, 2012, 10:27 AM | #6 |
MOTM - Apr '13
A precise fit to your speck case or to a naked iPhone?
October 26th, 2012, 11:48 AM | #7 |
Fast-Guy wannabe
MOTM - Jan '13
October 27th, 2012, 06:45 AM | #9 |
Fast-Guy wannabe
MOTM - Jan '13
Finished prototype #1
Ok so I've got more ideas for the next design to incorporate a felt lining to make the phone secure yet easy to insert and remove, right now it going nowhere |
October 27th, 2012, 08:25 AM | #10 |
Join Date: Sep 2012 Motorcycle(s): 2003 Kawasaki Ninja 250 Posts: 103
Anyway you could just make it so the sides slide, but are still secure? That may solve the different cases fitting properly issue. (I don't know how well this work, though.)
Edit: I've been thinking about this all day. Maybe the slide bars could just be attached to the main unit with a wing nut so you can loosen the nut, slide them apart, insert the phone, slide together, and then screw back in. The slide length wouldn't have to be huge or anything. I also recommend a LifeProof case (if they make one for the i5) because it is super water-proof and that mounting position is asking for water damage. Last futzed with by siebadn; October 27th, 2012 at 08:47 PM. |
October 27th, 2012, 10:00 PM | #11 |
Fast-Guy wannabe
MOTM - Jan '13
After using the iPhones turn by turn navi piped strait into my helmets speakers via Bluetooth I realized how awesome it was till I noticed my battery life dropping like a rock. So along came the cig lighter port and USB cable
RAM iphone 4 mount | Snowy | 2008 - 2012 Ninja 250R Farkles | 15 | May 12th, 2015 09:23 PM |
Dashboard iPhone 4 Mount | subiegy2010 | 2008 - 2012 Ninja 250R Farkles | 22 | March 25th, 2013 05:13 PM |
iPhone 5 mount | erbarry88 | General Motorcycling Discussion | 12 | February 22nd, 2013 05:34 AM |
Iphone mount | Yhames879 | 2008 - 2012 Ninja 250R Farkles | 7 | August 7th, 2012 12:40 PM |
My iPhone Mount | enko11 | 2008 - 2012 Ninja 250R Farkles | 2 | May 9th, 2012 09:04 AM |
