Old August 29th, 2016, 06:31 PM   #1
Glowing Ninja
Glowing Ninja's Avatar
Unhappy 07 Ninja Rear Wheel Adjustment Issue
Hello all, first i am sorry if there is a thread about this as i am unable to find it, so...
T all started when i had my back tire replaced... the bike would drift to the left if i didnt give it any input... i brought it up to other riders and a Mech. and they thought i was losing it.
Today. i went to tighten my chain and realized the right side tensioner was lose, so bad that it had spun upwards making my back tire go in a slight downward right angle. AHA! found that problem.
I know I should have noticed this before but...
SOO! I got my chain back to spec, (if 40mm is spec? if not, better then 2 1/2" *cough* ) and i went for a ride. As soon as i hit my back brake i felt a shift in the bike. I pulled over and looked and my rear wheel and the axle/tension assembly shifted back a whole notch on the right side (the notches for adjustment) and every time i put it back, when i hit the brake it slides backwards again.
Any Idea how to fix this??
Glowing Ninja is offline   Reply With Quote
Old August 29th, 2016, 06:35 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Pictures are worth 1000 words. If you can take pics of both sides of the axle, it would help a lot to see if parts are missing.
might just be the axle nut isn't tight enough too.
Goin' fast on slow bikes!
Old August 29th, 2016, 06:38 PM   #3
Glowing Ninja
i tried tightening it and it just spins for days. ill try to get a couple clear pics.
Old August 29th, 2016, 06:40 PM   #4
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
You have to hold the other end while you tighten the nut. Unless you mean the nut is stripped??
Old August 29th, 2016, 06:45 PM   #5
Glowing Ninja
nope, just didnt hold the other side lol, couldnt even if i wanted to as i was on the side of the road with very limited tools. Cant believe i didnt think of that. Going to log in with my phone and upload some pictures.
Old August 29th, 2016, 06:47 PM   #6
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Ah, gotcha!!
Well, here's what I would do. Adjust chain to where it should be and make both sides even. 2.5" of free play is too much, shoot for 1.5". Once that is done, tighten axle well and install a cotter pin in the castle nut to keep things from coming loose again.
Old August 29th, 2016, 07:11 PM   #7
Glowing Ninja
Cant seem to upload pics? tried tinypic. any suggestions?
Old August 29th, 2016, 07:12 PM   #8
Glowing Ninja
its at about 1.5. There already is a cotter pin in the nut?
Old August 29th, 2016, 07:15 PM   #9
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Sorry for the delay, had some issues :/
That chain is about junk. Once they're rusted like that (rusty colored powder in the pics) it's only matter of time. Clean it with WD40 and a brush then lube it. Check for kinked links that don't want to straighten out. If you have any, it's time to replace it. Also, the adjusters are pretty far out, which is an indication the chain is slightly too long or has stretched too much due to age and wear.
Tighten it up and see what happens.
Old August 29th, 2016, 07:17 PM   #10
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
For your pics, use just the link: http://i67.tinypic.com/2pq5746.jpg
Click the mountain with a sun icon in the post box and copy the link to the image there. No need for the other stuff.
Old August 29th, 2016, 07:20 PM   #11
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Not quite, use the link I posted in my post.
Old August 29th, 2016, 07:23 PM   #12
Glowing Ninja
I checked for kinks today and they all straightened up after some lube. I think its the original chain to be honest (previous owner said all was original)
But do you see anything missing that could cause the tire to move?
Old August 29th, 2016, 07:27 PM   #13
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Nothing other than the axle nut being loose (probably). Nothing looks to be out of place.
Old August 29th, 2016, 08:10 PM   #14
..........Any Idea how to fix this??
https://www.ninjette.org/forums/show...10&postcount=8
http://faq.ninja250.org/wiki/How_do_...chain_slack%3F
http://faq.ninja250.org/wiki/How_oft...se_to_do_so%3F
http://faq.ninja250.org/wiki/Final_Drive
Old August 29th, 2016, 08:19 PM   #15
Glowing Ninja
Well i went out, pulled the pin, tightened the axle nuts and repinned it. I then booted up the bike and tried it out. didnt move! Is it safe to safe that it was put back together loose from the person that put the new tire on??
and thanks motofool! i didnt torque it, i just used the "thats about right" method lol. ill go at it tomorrow with the TW.
Thank you guys! Dont know how i didnt think of any of this but ive very little experience working on bikes so i dont want to mess anything up lol.
Ill be back again with my engine tick questions later on in another thread if i dont find one on here that helps. (cam chain tensioner is what ive got out of it so far)
Thanks!!!
Old August 29th, 2016, 08:54 PM   #16
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Glad you got it sorted... That stuff is dangerous!
Old August 30th, 2016, 07:18 AM   #17
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Probably. The axle nut is what holds the axle and wheel in place. The adjusters are just used to pull things into place while you tighten the axle down.
Old August 30th, 2016, 11:28 AM   #18
Glowing Ninja
ok. I guess thats what i get for going to a honda shop. haha
Ohio "Dragon Tail" Rider
Old August 30th, 2016, 11:30 AM   #19
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Eh, all motorcycles are the same when it comes to axles, except for those with single sided swingarms. They should have known better.
I wouldn't go to that shop again though. Things like basic maintenance shouldn't be screwed up by anyone getting paid to work there.
Old August 30th, 2016, 11:41 AM   #20
Glowing Ninja
yeah, i had to talk them into doing it. they didnt want to touch my bike because it wasent a honda and they just kept saying "We only work on hondas". It was either that or take a LONG ride just for a tire.
Chain Adjustment Issue z0sum 2008 - 2012 Ninja 250R Tech Talk 10 August 6th, 2016 06:23 AM
Chain Adjustment/Rear Wheel Alignment? z0sum 2008 - 2012 Ninja 250R Tech Talk 10 June 17th, 2016 08:32 AM
DIY- Chain Adjustment and Rear Wheel Alignment kkim General Motorcycling Discussion 76 January 14th, 2015 12:56 AM
2010 Ninja 250r - Rear Shock, Adjustment Tool, and Linkage conrya5 Motorcycle-related 19 June 2nd, 2013 02:57 PM
Valve adjustment Issue cgborders 1986 - 2007 Ninja 250R Tech Talk 7 February 14th, 2012 07:34 PM
