Old September 13th, 2009, 06:51 PM   #1
Digiadaamore
Digiadaamore's Avatar
Motorcycle(s): None Yet
k&n drop in vs pods
Hi all im a new member and id just like to say the knowledge and maturity on this forum is great but to my question.i will be picking up a used(obviously) 08 250r and the mods i plan are an areap full exhaust,dynojet stage 2 kit,full synthetic oil,iridium spark plugs and just general tuning.i was wondering if there would be a significant advantage going with pods over a k&n drop in and if its worth the added work also anyone who has done pods could i just a quick rundown on what exactly is involved in upgrading to them thanks
Digiadaamore is offline   Reply With Quote
Old September 13th, 2009, 07:00 PM   #2
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
you'll need a new set of main jets. 110's minumum. I would go with the drop in unless you don't care about your mileage that much. No real advantage maybe a little better throttle response.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old September 13th, 2009, 07:01 PM   #3
pods require you to pull the airbox out. it is a involved, time consuming job. with pods, you will also need to use larger main jets.
powerwise, the top end remains about the same, but power is gained throughout the powerband from low to high end.
my suggestion is to go with a slip in filter for the airbox for now. you can always go to pods later if you are not happy with just setting up your bike w/ a drop in filter.
pic of my bike when I was pulling the airbox.
Old September 13th, 2009, 07:03 PM   #4
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Hi Wes, you're already in great hands, but I wanted to say Welcome!
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old September 13th, 2009, 07:04 PM   #5
Digiadaamore
thanks im not too worried about mileage as the bike is already going to be great for that i figure even if it drops it'll still be pretty good.(plus my wringing it out will lower it anyways) thanks
Old September 13th, 2009, 07:10 PM   #6
Digiadaamore
thanks for the pic i figure your right on about trying the drop in first.after i get the bike ill ride it for probably about 6 monthes or so too get totally comfortable with it(and procure the necessary funds)then do my planned upgrades.the way i figure if i do the exhaust,dynojet kit and filter at the same time ill be so happy with the results i probably wont even be worried about the slight advantage pods might give me.p.s. thanks for the quick answers
Old September 14th, 2009, 05:35 AM   #7
Digiadaamore
can anyone give me a recommendation as to main jet size if i go with a drop in(not sure if you meant i dont have to change them if i go for the drop in or what)and which position my needles should be at.i know every bikes different but its good to have something to start from
Old September 14th, 2009, 10:15 AM   #8
stock main jets. shim the needles with 2 or 3 washers.
Old September 14th, 2009, 11:12 AM   #9
empire00
empire00's Avatar
Motorcycle(s): 2009 250r SE, 2015 FJ-09
kkim you left the plate visible in your pic fyi
empire00 is offline   Reply With Quote
Old September 14th, 2009, 11:25 AM   #10
thanks... it's not an issue for me.
Digiadaamore- have you read this thread? http://www.ninjette.org/forums/showthread.php?t=10208
Old September 14th, 2009, 08:05 PM   #11
Digiadaamore
thanks kkim i was just a little confused because there are so many different set-ups and opinions(i take yours as being correct).and yes ive read that thread but again just so many different set-ups,however i believe what thebulboseone is running is exactly what i want so i think thats where im going start and fine tune from there
Old September 14th, 2009, 08:18 PM   #12
Digiadaamore
kkim just saw the thread on snorkel removal could i do that with stock main jets and three washers?or would i need a bigger main/more washers
Old September 14th, 2009, 09:24 PM   #13
Focus Mike
Motorcycle(s): 2009 Blue Ninja 250R
Unless someone wants to fly to hawaii and steal his bike and then ship it which will cost a ton of money to the states I would venture to say Kkim is going to be just fine.
He also trained BJ Penn to fight so you know....
Focus Mike is offline   Reply With Quote
Old September 14th, 2009, 10:30 PM   #14
if you are using the airbox, that setup should work fine.
Old September 15th, 2009, 07:43 PM   #15
Digiadaamore
thanks again
Old September 16th, 2009, 08:39 PM   #16
mista350z
Motorcycle(s): 08 CBR600rr, 08 Ninja 250r - sold
I am thinking about the K&N drop in too. Is it worth it the price though? Are you able to tell a difference? performance or sound wise?
mista350z is offline   Reply With Quote
Old September 16th, 2009, 09:15 PM   #17
ztrack157
The Sportisi Master
ztrack157's Avatar
Um my dyno's show a 0.5-1.0 HP gain by a drop in JFC filter which is what I sell, (KN is made of the same material) so I imagine a similar gain.
Old September 16th, 2009, 09:22 PM   #18
mista350z
does it make a louder air intake sound?
Old September 16th, 2009, 09:34 PM   #19
ztrack157
The Sportisi Master
ztrack157's Avatar
only if you fart while riding. its not like a cold air intake on a car.
Old September 16th, 2009, 09:59 PM   #20
mista350z
haha...thats what i was wondering
Old September 17th, 2009, 06:58 AM   #21
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
I'd see how your mileage does with the drop-in before you go to pods. I have the air box pulled and air pods and my MPG has been really lousy lately. I'm suspecting the air pods have a lot to do with it.
TrueFaith is offline   Reply With Quote
Old September 17th, 2009, 11:19 AM   #22
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
is that a GREEN hex wrench set under the bike? I hear some think they spin faster.
Old September 17th, 2009, 11:25 AM   #23
yes... definitely faster than the red, blue or black versions they offer. thanks for asking.
Old September 18th, 2009, 09:29 PM   #24
coffeecandy
Motorcycle(s): 2002 Ninja 250
pods are quite cheap on amazon
Bay Area Event Coming Up:
June 2, 2012 Mike's Newb Group Ride
coffeecandy is offline   Reply With Quote
Old October 1st, 2009, 08:09 PM   #25
caferacer
Caferacer
caferacer's Avatar
I haven't had the pleasure of pulling my bike completely apart to remove the air box on my 250r yet, but I have done it on virtually every other bike I have owned. From the pics, I cannot see the hassle vs. benefit over just removing the snorkel and rejetting. My experience it that the smaller the bike, the harder it is to get the jetting just right. I had couple Honda CB-1 's a few years back (400 cc , 4 cylinder) I put pods on one and a K & N factory style on the other...I liked to never got the one with the pods right...Months of frustration...in hindsight, I just cannot see the horsepower benefit of the pods on the 250R for the street. If your setup is for racing or day racing then definitely.
caferacer is offline   Reply With Quote
Issue with K&N pods parox91 1986 - 2007 Ninja 250R Tech Talk 8 October 28th, 2013 06:41 AM
Free: K&n 0990 pods Trailerboy531 Free stuff! 10 September 11th, 2013 01:45 PM
Jetting for K&N Pods 1994Ninja250F 1986 - 2007 Ninja 250R Tech Talk 10 January 25th, 2011 11:44 AM
Chopped fender & Installed lights in pods Snake 1986 - 2007 Ninja 250R Farkles 22 January 19th, 2010 12:48 AM
Question about UNI pods\K&N air filters cbass78 1986 - 2007 Ninja 250R Tech Talk 6 March 22nd, 2009 06:28 PM
