September 19th, 2014, 07:17 AM | #1 |
Join Date: Nov 2012 Motorcycle(s): Ugly 89 frankenstien special ex250, and the "Zooks" : 1982 GS450 and 1979 GS1000 Posts: 327
Petcock pickup tube length??
Hey guys and gals quick question for someone who has a petcock laying around somewhere...What is the length for each of the pickup tubes on the petcock? Both my petcocks had the tubes broken off, last time I put it together I just stuck a piece of 1/4" teflon tubing in the "run" side and let reserve pull off the bottom of the tank. Obviosly my carbs fill up with crap every time it goes on reserve.
So now I've got some copper tubing and I was going to have reserve come up about an inch above the bottom of the tank, and maybe 2.5 inches for the run tube? Is that close to stock? I just want to avoid a reserve much different from stock, and as big a pain as it can be to drain the gas tank and pull the petcock off I'd like to get it right the first time. THANKS!!
Oh god the bikes are multiplying!!! |
September 19th, 2014, 09:03 AM | #2 |
Join Date: Feb 2014 Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total) Posts: 465
The upper tube is solid brass for 8 cm, topped with a 3.5 cm (including plastic base) filter screen. The reserve tube is a similar filter screen to that above pushed onto a fitting in the petcock.
If you aren't going to clean the tank (recommended), which it sounds like is the source of contaminants, you ought to consider adding a transparent inline fuel filter so you can see when it gets clogged up. http://www.amazon.com/Visu-Filter-In...068296&sr=1-14 |
September 19th, 2014, 10:39 AM | #3 | |
September 19th, 2014, 08:12 PM | #4 |
I urge everyone who wants to seal their tank not to use Kreem, Red Kote, POR-13 or any other "flexible" liners. Too many of them fail and then you have a worse problem getting the failed liner out. I speak from personal experience here.
Caswell epoxy tank sealer is what you should use. Once dry, it is impervious to fuel and water in the tank. It won't fail if the tank is properly prepped and applied according to instructions. http://www.caswellplating.com/restor...nk-sealer.html |
September 23rd, 2014, 08:36 AM | #5 | |
September 24th, 2014, 07:55 PM | #6 |
Not sure what was in your tank, but doubt it was Caswell. If applied properly, it isn't coming off. It actually adheres to light rust better than a perfectly clean tank.
I bought a bike that the Kawasaki dealer had convinced the PO needed to be sealed, so they Kreemed it. In less than a year, it was rusting under the Kreem, which was a pain to get out. I cleaned the rust out and the tank never has leaked. The stealership could have done the same thing, but decided to stick it to the PO instead by telling him it needed to be sealed. If a tank isn't leaking, it doesn't need to be sealed. |
September 25th, 2014, 02:45 PM | #7 |
Join Date: May 2013 Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50. Posts: 186
You could always buy a new tank, in the U.S. you only pay about $700-$800. Here in Australia they want $1,380. :-)
Originally Posted by jgcable; I ride a 2006 Custom HD Wideglide..... and I almost have to sign autographs when I park it. |
September 26th, 2014, 08:01 AM | #8 | ||
Hmm, wonder how much to ship one to Oz for you...
New Pickup - Eventual Build Thread | ninjakuma | The Ex-Ninjetters Lair | 9 | August 22nd, 2014 11:36 AM |
Vacuum nipple came off petcock - fix or replace petcock? | fierostetz | 1986 - 2007 Ninja 250R Tech Talk | 3 | November 24th, 2012 11:03 AM |
Gas Pouring out of Overflow Tube - Bowls or Petcock? | Jim Moore | 1986 - 2007 Ninja 250R Tech Talk | 7 | October 30th, 2012 01:03 PM |
[topix.net] - From Twin-Tube Single Shocks to Single-Tube Twin Shocks: Ohlins... | Ninjette Newsbot | Motorcycling News | 0 | June 5th, 2012 04:30 AM |
[sportrider - latest stories] - From Twin-Tube Single Shocks to Single-Tube Twin Shoc | Ninjette Newsbot | Motorcycling News | 0 | June 4th, 2012 06:40 PM |
